Zum Hauptinhalt wechseln
Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement
Was du brauchst
  1. Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement, 3.5 mm Headphone Jack: Schritt 1, Bild 1 von 3 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement, 3.5 mm Headphone Jack: Schritt 1, Bild 2 von 3 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement, 3.5 mm Headphone Jack: Schritt 1, Bild 3 von 3
    • This is the back of the device and where you will begin to take it apart.
    • It is necessary to remove the silver piece covering the camera first before removing the bigger back piece.
    • Use a metal spudger to pop up the corner of the silver piece.
    • Use the plastic opening tools to pry along the edges of the silver piece.
    • Lift up the silver piece to reveal the rest of the back cover.
  2. Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: Schritt 2, Bild 1 von 3 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: Schritt 2, Bild 2 von 3 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: Schritt 2, Bild 3 von 3
    • Remove the three 5mm screws indicated by the red circles with the Phillips #00 screwdriver.
    • Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
    • Remove the back cover.
    • At this point use anti-static gloves or do NOT take it apart on carpet.
  3. Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: Schritt 3, Bild 1 von 3 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: Schritt 3, Bild 2 von 3 Samsung Galaxy Note 10.1 3.5 mm Headphone Jack Replacement: Schritt 3, Bild 3 von 3
    • Remove the three 2 mm screws indicated by the red circles with the Phillips #00 screwdriver.
    • Starting with the black motherboard connector, remove the module indicated by the orange box in the second picture.
    • Replace the 3.5 mm auxiliary port with a similar model.
Abschluss
Gavin Tipker
193 Reputation
2 Anleitungen geschrieben
IUPUI, Team S3-G1, Harley Fall 2018 Mitglied von IUPUI, Team S3-G1, Harley Fall 2018
IUPUI-HARLEY-F18S3G1
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 995
