Zum Hauptinhalt wechseln
Toro Lawn Mower Cutting Blade Replacement
Was du brauchst
  1. Toro Lawn Mower Cutting Blade Replacement, Cutting Blade: Schritt 1, Bild 1 von 1
    • Disconnect the spark plug to ensure that the lawn mower does not accidentally turn over and cause the mower to turn on.
  2. Toro Lawn Mower Cutting Blade Replacement: Schritt 2, Bild 1 von 1
    • Flip the mower onto its side exposing the blade and under carriage.
  3. Toro Lawn Mower Cutting Blade Replacement: Schritt 3, Bild 1 von 1
    • Place wood in between the blade and the wall of the mower to ensure that the blade does not move while you are tightening or loosening the bolt.
  4. Toro Lawn Mower Cutting Blade Replacement: Schritt 4, Bild 1 von 1
    • Using the 5/8 wrench, turn the blade counter clockwise until the bolt is loose then pull the blade off.
    • Make sure that safety gloves are worn at all times when handling the new or old cutting blade.
  5. Toro Lawn Mower Cutting Blade Replacement: Schritt 5, Bild 1 von 1
    • Place the new blade in right side up into the bracket and line up the bolt.
    • Make sure that safety gloves are being worn at all times when handling either the new or old cutting blade.
  6. Toro Lawn Mower Cutting Blade Replacement: Schritt 6, Bild 1 von 1
    • Using the 5/8 ratchet, turn the bolt clockwise until the bolt does not turn anymore.
  7. Toro Lawn Mower Cutting Blade Replacement: Schritt 7, Bild 1 von 1
    • Flip the mower right-side up and reconnect the spark plug.
Abschluss
This simple fix should help make the lawn mower function efficiently and safely for years to come.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 23
Letzte 7 Tage: 131
Letzte 30 Tage: 384
Insgesamt: 4,272
