Zum Hauptinhalt wechseln
Motorola i710 LCD Screen Cover Replacement
Was du brauchst
  1. Motorola i710 LCD Screen Cover Replacement, Battery Cover: Schritt 1, Bild 1 von 2 Motorola i710 LCD Screen Cover Replacement, Battery Cover: Schritt 1, Bild 2 von 2
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
  2. Motorola i710 LCD Screen Cover Replacement, Battery: Schritt 2, Bild 1 von 1
    • Push the battery towards the top of the phone and lift up.
  3. Motorola i710 LCD Screen Cover Replacement, LCD Screen Cover: Schritt 3, Bild 1 von 3 Motorola i710 LCD Screen Cover Replacement, LCD Screen Cover: Schritt 3, Bild 2 von 3 Motorola i710 LCD Screen Cover Replacement, LCD Screen Cover: Schritt 3, Bild 3 von 3
    • Although the lower half of the phone in these images has been disassembled, it is not necessary for removing the LCD screen.
    • With the help of plastic opening tools, remove the i710 name plate and Motorola logo from the backside of the phone.
    • The four screws holding the upper half of the phone together should now be visible.
  4. Motorola i710 LCD Screen Cover Replacement: Schritt 4, Bild 1 von 2 Motorola i710 LCD Screen Cover Replacement: Schritt 4, Bild 2 von 2
    • With a H1.5 screwdriver, unscrew the four H1.5 sized screws from the back of the phone.
    • Flip the phone onto its back and, with the help of a plastic opening tool, remove the metal speaker cover that is above the LCD screen.
  5. Motorola i710 LCD Screen Cover Replacement: Schritt 5, Bild 1 von 3 Motorola i710 LCD Screen Cover Replacement: Schritt 5, Bild 2 von 3 Motorola i710 LCD Screen Cover Replacement: Schritt 5, Bild 3 von 3
    • Slide a plastic opening tool along the edge of the LCD Screen Cover to separate the cover from the phone casing. Apply a small amount of force towards the cover if necessary.
    • The LCD screen should now be completely separated from the phone.
Abschluss
Carson Meena
16 Reputation
5 Anleitungen geschrieben
Clemson, Team 14-2, Benson Fall 2012 Mitglied von Clemson, Team 14-2, Benson Fall 2012
CLEM-BENSON-F12S14G2
4 Mitglieder
17 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 372
