Einleitung
Once the LCD Screen Cover has been removed, the LCD Screen can be accessed as shown in this guide.
Was du brauchst
Slide the cover release button towards the bottom of the phone
Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
With the help of plastic opening tools, remove the i710 name plate and Motorola logo from the backside of the phone.
The four screws holding the upper half of the phone together should now be visible.
With a H1.5 screwdriver, unscrew the four H1.5 sized screws from the back of the phone.
Flip the phone onto its back and, with the help of a plastic opening tool, remove the metal speaker cover that is above the LCD screen.
Slide a plastic opening tool along the edge of the LCD Screen Cover to separate the cover from the phone casing. Apply a small amount of force towards the cover if necessary.
The LCD screen should now be completely separated from the phone.
Use a spudger to detach the ribbon cable connecting the the LCD Screen to the rest of the phone.
The LCD Scren will now lift out from the phone casing.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
