Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein RedOctane X-Plorer zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. RedOctane X-Plorer Teardown, Case: Schritt 1, Bild 1 von 1
    • Remove all 16 #10-torx screws from the back side of the case.
    • Gently separate the case pieces.
    • A strong magnet helps greatly when taking out the screws.
    • Keep in mind when resembling, the case is plastic so, don't tighten the screws too tight.
  2. RedOctane X-Plorer Teardown, Neck: Schritt 2, Bild 1 von 1
    • Unscrew the 4 #10-torx screws.
  3. RedOctane X-Plorer Teardown, Colored Keys: Schritt 3, Bild 1 von 3 RedOctane X-Plorer Teardown, Colored Keys: Schritt 3, Bild 2 von 3 RedOctane X-Plorer Teardown, Colored Keys: Schritt 3, Bild 3 von 3
    • Unscrew the 2 Philips head screws
    • Peel off the pads.
    • Push the colored keys out from the other side.
  4. RedOctane X-Plorer Teardown, Strum Bar: Schritt 4, Bild 1 von 3 RedOctane X-Plorer Teardown, Strum Bar: Schritt 4, Bild 2 von 3 RedOctane X-Plorer Teardown, Strum Bar: Schritt 4, Bild 3 von 3
    • Unscrew the red screws and pull the board out.
    • Then, unscrew the blue screws
    • Pull the bracket things off.
    • Pull out the pin.
  5. RedOctane X-Plorer Teardown, Unused port: Schritt 5, Bild 1 von 1
    • Unscrew the 4 Philips head screws.
  6. RedOctane X-Plorer Teardown, Aux Port: Schritt 6, Bild 1 von 1
    • Unscrew these 2 Philips head screws.
  7. RedOctane X-Plorer Teardown, Whammy Bar: Schritt 7, Bild 1 von 2 RedOctane X-Plorer Teardown, Whammy Bar: Schritt 7, Bild 2 von 2
    • Push from the other side until it comes out.
    • Take the spring off with the connector
  8. RedOctane X-Plorer Teardown, Motherboard: Schritt 8, Bild 1 von 2 RedOctane X-Plorer Teardown, Motherboard: Schritt 8, Bild 2 von 2
    • Peel off the contact pads.
Jackson Poer
671 Reputation
2 Anleitungen geschrieben
Ein Kommentar
"unused port" is for a footpedal switch,not positive but believe all GH style guitars have one
Valden Tharbosen - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 21
Letzte 30 Tage: 66
Insgesamt: 3,350
