Zum Hauptinhalt wechseln
IBM ThinkPad T30 Keyboard Replacement
Was du brauchst
  1. IBM ThinkPad T30 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 3 IBM ThinkPad T30 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 3 IBM ThinkPad T30 Keyboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • Make sure the ThinkPad is off and the power supply is unplugged.
    • Flip the ThinkPad upside down with the bottom facing you.
    • Slide the latch to the right into the unlock position.
    • While holding the latch in the unlock position, lift the battery out with your other hand.
  2. IBM ThinkPad T30 Keyboard Replacement, Keyboard: Schritt 2, Bild 1 von 2 IBM ThinkPad T30 Keyboard Replacement, Keyboard: Schritt 2, Bild 2 von 2
    • Begin by removing the two black 16 mm Phillips #0 screws. The screws can be identified by the two notches next to each screw. One (marked in red) is near the battery lock and the other (not pictured) is next to the Wi-Fi cover.
    • Push up the bottom of the keyboard by poking your finger through the hole to the right of the yellow bios battery. You will feel slight resistance.
    • Be sure to not lift the keyboard too far. It is still attached to the computer with a ribbon connector.
  3. IBM ThinkPad T30 Keyboard Replacement: Schritt 3, Bild 1 von 3 IBM ThinkPad T30 Keyboard Replacement: Schritt 3, Bild 2 von 3 IBM ThinkPad T30 Keyboard Replacement: Schritt 3, Bild 3 von 3
    • Lift the keyboard to expose the ribbon connector and lean it against the computer screen to keep the ribbon intact.
    • If the ribbon is broken, the keyboard is permanently unusable and needs to be replaced
    • Use the plastic opening tool to gently pry the connector up from the motherboard.
    • You can now safely remove the keyboard.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Alex Kost
271 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 3-20, Amido Fall 2012 Mitglied von Cal Poly, Team 3-20, Amido Fall 2012
CPSU-AMIDO-F12S3G20
3 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 23
Insgesamt: 2,973
