Zum Hauptinhalt wechseln
Toshiba Satellite C55-A5286 Optical Drive Replacement
Was du brauchst
  1. Toshiba Satellite C55-A5286 Optical Drive Replacement, Optical Drive: Schritt 1, Bild 1 von 1
    • Unplug the AC adapter and all other auxiliary components from the laptop
  2. Toshiba Satellite C55-A5286 Optical Drive Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite C55-A5286 Optical Drive Replacement: Schritt 2, Bild 2 von 2
    • Unscrew the only screw (5 mm) that is holding on the removable back panel and remove the back panel.
  3. Toshiba Satellite C55-A5286 Optical Drive Replacement: Schritt 3, Bild 1 von 1
    • Remove the two 5-mm screws near the disk drive on the back panel. These two screws are above and below the manufacturer’s sticker.
  4. Toshiba Satellite C55-A5286 Optical Drive Replacement: Schritt 4, Bild 1 von 1
    • Under the back panel, remove the 4-mm screw holding the disk drive in place.
  5. Toshiba Satellite C55-A5286 Optical Drive Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite C55-A5286 Optical Drive Replacement: Schritt 5, Bild 2 von 2
    • Carefully slide the optical drive out of its place in the laptop.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Nicole Zellers
265 Reputation
2 Anleitungen geschrieben
IUPUI, Team S1-G5, Hovde Fall 2018 Mitglied von IUPUI, Team S1-G5, Hovde Fall 2018
IUPUI-HOVDE-F18S1G5
2 Mitglieder
9 Anleitungen geschrieben
Ein Kommentar
Not a medium effort at all - very easy.
…although, I did have to use an iFixt It needle-nose tweezer to pull the middle 5mm screw out after it was unscrewed - it would not fall out nor did it cling to the screwdriver.
William Totman - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 12
Insgesamt: 293
