Einleitung
The heat sink, along with the fan, helps keep the laptop from overheating. If the heat sink is damaged through be clogged that can’t be removed by the fan or cleaning, then a replacement is necessary to prolong the life and durability of the laptop.
Was du brauchst
Pry the heat sink away from the laptop with two hands at both ends and remove it from the device.
Fast fertig!
Abschluss
