Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein ThinkPad 10 (20C1) zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. ThinkPad 10 (20C1) Teardown, Open the Backcover: Schritt 1, Bild 1 von 1
    • You should follow this video: https://support.lenovo.com/de/de/videos/...
    • A plastic Opening Tool is maybe helpful
    • I have done it in a different way:
    • You need a bag, that is not providing too much protection, a wet street and a bicycle with working breaks.
    • I don't recommend this strategy, because you will most likely also teardown some of your body. (I'm okay, but I won't do it again)
  2. ThinkPad 10 (20C1) Teardown, Overview: Schritt 2, Bild 1 von 1
    • We take a closer look later
    • It's the battery, a 3.7V 8.72Ah Li-ion. Partnumber: 45N1729 or 45N1727 or 45N1726
    • The PCB of the frontfacing camera and luminance sensor. P/N: 45N1729
    • The power connector board with the USB Type A connector. P/N: 00HW298
    • Speakers, P/N: 45N1729
    • Board with docking connections. P/N: 00HW296
    • The red LED of the ThinkPad Logo
  3. ThinkPad 10 (20C1) Teardown, Closer Look: Schritt 3, Bild 1 von 2 ThinkPad 10 (20C1) Teardown, Closer Look: Schritt 3, Bild 2 von 2
    • 8 MP Rear Facing Camera. P/N: 04X1392
    • Wifi Module. It's compared to the WWAN Module pretty tiny
    • WWAN UMTS Module. Gets you connected nearly everywhere. P/N: 04X6014
    • SIM Card
    • The buttons for power and rotation lock. P/N: 00HW309
    • 3.5 mm Headphone jack, or why this device is better than an iPhone 7.
  4. ThinkPad 10 (20C1) Teardown, Slots on the side: Schritt 4, Bild 1 von 1
    • SIM Card. Contacts are facing backwards
    • MicroSD Card. Sadly it is impossible to boot from it
    • The modelnumber, here: 20C10024MB
    • There would be the serial number
    • The volume control
    • The fingerprint reader
  5. ThinkPad 10 (20C1) Teardown, The Alternative Opening Method: Schritt 5, Bild 1 von 2 ThinkPad 10 (20C1) Teardown, The Alternative Opening Method: Schritt 5, Bild 2 von 2
    • The aluminium back cover has absorbed very much energy during the impact. It's really difficult to bend it back. To my luck, nothing else was damaged
    • Even without the backcover, the tablet is working fine
Quanten
1.013 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 32
Letzte 30 Tage: 106
Insgesamt: 6,188
