Zum Hauptinhalt wechseln
Canon EOS 60D: Replacing Eye piece and Battery door
  1. Canon EOS 60D: Replacing Eye piece and Battery door, Eye piece and Battery door: Schritt 1, Bild 1 von 2 Canon EOS 60D: Replacing Eye piece and Battery door, Eye piece and Battery door: Schritt 1, Bild 2 von 2
    • Removing the eyepiece is easy. There are two methods, you can do it yourself, or put it in your camera bag a dozen times and at least once, it will fall off.
    • Grip the eyepiece by the sides firmly (index finger and thumb). Wiggle it upwards until it is off.
  2. Canon EOS 60D: Replacing Eye piece and Battery door: Schritt 2, Bild 1 von 2 Canon EOS 60D: Replacing Eye piece and Battery door: Schritt 2, Bild 2 von 2
    • Open the battery door
    • Rotate the door so the one side of the hinge pops out (see photo #2)
    • Slide other pin out (it pops out the same, but this is easier)
Abschluss
Rubber grips will require adhesive. (I havent gotten this far, I assume rubber cement / double stick tape may work)
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Eric D
1.284 Reputation
5 Anleitungen geschrieben
Ein Kommentar
But how do you REPLACE the rubber eye piece? Mine seems to be NOT glued, but in a tract of sorts.
Wendell C Durnil - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 28
Insgesamt: 5,941
