Was du brauchst
My Macintosh Color Classic running under MacOS 7.6 some days before it died
The chassis and the power supply board were cleaned up and adapted for fitting the new components.
12 Kommentare
La pantalla es lo que mas temor da retirar si es igual a las de la emac y imacs, me gustaría haberlo hecho con la que me dañaron en un taller, no la guarde y tire la basura, en fin jamas se sabe lo que la tecnología nueva nos permite hacer con las viejas carcazas, debe ser grato ver la cara de la gente que te ve trabajar en ella con teclado y ratón inalámbricos.
Do you have a more detailed breakdown, including exact parts used. I have one of these Macs and it has died. The sentimental value is huge so doing to it what you did to yours is an awesome idea. Thanks
Sorry, I haven’t more details of the breakdown. The most difficult part was to clean up the power supply board and to saw parts of the plastic chassis to fit the MacMini inside. The parts I kept from the original machine are the chassis, the power supply board and the framework that sustained the original screen.
Roberto -
Roberto, what size is the fan? 60x25mm? And can you remove the stock fan from that metal housing so as to replace it with a quieter modern version? Thanks.
