Zum Hauptinhalt wechseln
PSP Go Analog Joystick Replacement
Was du brauchst
  1. PSP Go Analog Joystick Replacement, Back Cover: Schritt 1, Bild 1 von 2 PSP Go Analog Joystick Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Unscrew the four Phillips screws on the back of the PSP Go.
    • Rotate the PSP so you can see the top of the device.
    • Unscrew the two Phillips screws next to the volume buttons.
  2. PSP Go Analog Joystick Replacement: Schritt 2, Bild 1 von 2 PSP Go Analog Joystick Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool around the perimeter of the back cover to loosen it on all sides.
    • Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
    • Be careful not to rotate the back cover from the bottom, as you will break the plastic screw holes on top of the device.
  3. PSP Go Analog Joystick Replacement, Top Cover: Schritt 3, Bild 1 von 1
    • Pull the top cover upwards gently from its housing.
  4. PSP Go Analog Joystick Replacement, Bottom Plate: Schritt 4, Bild 1 von 2 PSP Go Analog Joystick Replacement, Bottom Plate: Schritt 4, Bild 2 von 2
    • Remove the two Phillips screws holding the bottom plate.
    • Gently lift the bottom plate away from the device.
  5. PSP Go Analog Joystick Replacement, Analog Joystick: Schritt 5, Bild 1 von 1
    • Use a #00 Phillips screwdriver to remove both screws holding the analog joystick in place.
  6. PSP Go Analog Joystick Replacement: Schritt 6, Bild 1 von 2 PSP Go Analog Joystick Replacement: Schritt 6, Bild 2 von 2
    • Use a plastic opening tool to gently flip up the analog joystick's cable connector.
    • Use your fingers or tweezers to gently pull out the analog joystick cable from its connector.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 21
Letzte 30 Tage: 87
Insgesamt: 21,848
