Einleitung
In this section, you will observe how to very easily remove a damaged or malfunctioning keyboard. This breakdown of components can be done with ease: simply follow each step using the required tools. Tools needed are:
- Spudger
- Screwdriver
- Bit J00
Was du brauchst
Locate the keyboard and the led display cover.
Using the prying tool, go to the furthest right side of the keyboard cover and wedge upwards to lift the component out.
Locate the two M2.5X5mm screws and loosen using the J00 bit.
Locate the tab above the F7 and F8 keys.
Pull up and toward the screen to remove the keyboard from the main component.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
