Zum Hauptinhalt wechseln
Disassembling Nexus 4 Case, USB Flex, Mainboard, Headphone Jack, Screen etc.
Was du brauchst
Einführungsvideo
  1. Disassembling Nexus 4 Case, USB Flex, Mainboard, Headphone Jack, Screen etc., Case, Battery, USB Flex, Mainboard, Headphone Jack, Screen etc.: Schritt 1, Bild 1 von 3 Disassembling Nexus 4 Case, USB Flex, Mainboard, Headphone Jack, Screen etc., Case, Battery, USB Flex, Mainboard, Headphone Jack, Screen etc.: Schritt 1, Bild 2 von 3 Disassembling Nexus 4 Case, USB Flex, Mainboard, Headphone Jack, Screen etc., Case, Battery, USB Flex, Mainboard, Headphone Jack, Screen etc.: Schritt 1, Bild 3 von 3
    • Opening the case
Abschluss
To reassemble your device, follow the complete video
46 weitere Nutzer:innen haben diese Anleitung absolviert.
LE55ONS
10.977 Reputation
6 Anleitungen geschrieben
7 Kommentare
fantastic video guide! thanks
Carlo - Antwort
Brilliant, best that I have found.
andy brown - Antwort
Thank you for this excellent video guide !
Matthieu Imbert - Antwort
Thanks for the excellent guide. Your video has perfect quality, its easy to follow. With the help of your guide I was able to change the damaged screen in about 20 min.
Michael Pirker - Antwort
Excellent guide. I managed to change a broken screen in a couple of hours. Well, it actually took a little longer... the digitizer was broken but the LCD looked ok so I just bought the digitizer (around $14 on ebay) and then separated the LCD from the broken digitizer. It really hard. I ended up with a broken LCD. So I bought the LCD+Digitizer ($46) and that was easy. Its working fine now.
Pedro - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 34,644
