Zum Hauptinhalt wechseln
2003-2008 Pontiac Vibe Tail Light Bulb Replacement
Was du brauchst
  1. 2003-2008 Pontiac Vibe Tail Light Bulb Replacement, Tail Light Bulb: Schritt 1, Bild 1 von 1
    • Begin by opening up the rear hatch door by reaching under the "Pontiac" logo and pressing on the rear hatch door button.
    • Pull on the door from the same location to open the rear hatch.
  2. 2003-2008 Pontiac Vibe Tail Light Bulb Replacement: Schritt 2, Bild 1 von 1
    • Locate the tail light access doors on the left and right sides in the trunk compartment.
  3. 2003-2008 Pontiac Vibe Tail Light Bulb Replacement: Schritt 3, Bild 1 von 3 2003-2008 Pontiac Vibe Tail Light Bulb Replacement: Schritt 3, Bild 2 von 3 2003-2008 Pontiac Vibe Tail Light Bulb Replacement: Schritt 3, Bild 3 von 3
    • Press in on the opening tab and pull on the door to release the two clips on the left side.
    • Completely remove the access door and set it off to the side.
  4. 2003-2008 Pontiac Vibe Tail Light Bulb Replacement: Schritt 4, Bild 1 von 3 2003-2008 Pontiac Vibe Tail Light Bulb Replacement: Schritt 4, Bild 2 von 3 2003-2008 Pontiac Vibe Tail Light Bulb Replacement: Schritt 4, Bild 3 von 3
    • Inside of the compartment, there is the tail light bulb at the top, and the turn signal bulb on the bottom.
    • Reach inside with your hand and grab onto the tail light bulb socket. Rotate it counter-clockwise to unseat it from the tail light and remove the socket.
  5. 2003-2008 Pontiac Vibe Tail Light Bulb Replacement: Schritt 5, Bild 1 von 2 2003-2008 Pontiac Vibe Tail Light Bulb Replacement: Schritt 5, Bild 2 von 2
    • Hold onto the bulb socket and gently pull out the bulb with your other hand.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Craig Lloyd
35.418 Reputation
82 Anleitungen geschrieben
2 Kommentare
How do I replace the 3rd brake light?
Jennifer Trissell - Antwort
What about the 3rd bulb
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 26
Letzte 30 Tage: 91
Insgesamt: 9,236
