Zum Hauptinhalt wechseln
Draft Inducer Motor Replacement
Was du brauchst
  1. Draft Inducer Motor Replacement, Draft Inducer Motor: Schritt 1, Bild 1 von 2 Draft Inducer Motor Replacement, Draft Inducer Motor: Schritt 1, Bild 2 von 2
    • Start by turning off the flow of gas to your furnace, as well as cutting power to the whole furnace by flipping the service switch to the "Off" position.
    • If your furnace doesn't have a service switch nearby, you'll need to cut power to it at the breaker box.
  2. Draft Inducer Motor Replacement: Schritt 2, Bild 1 von 2 Draft Inducer Motor Replacement: Schritt 2, Bild 2 von 2
    • Grab the handle on the front panel marked "Lift" and push up to release the panel. Place it off to the side.
  3. Draft Inducer Motor Replacement: Schritt 3, Bild 1 von 3 Draft Inducer Motor Replacement: Schritt 3, Bild 2 von 3 Draft Inducer Motor Replacement: Schritt 3, Bild 3 von 3
    • The draft inducer is located in the upper-left area of the furnace chamber.
    • Unplug the motor's Molex connector.
    • Your specific furnace model may use a draft inducer with two small connectors on the motor itself, rather than a single Molex connector.
  4. Draft Inducer Motor Replacement: Schritt 4, Bild 1 von 2 Draft Inducer Motor Replacement: Schritt 4, Bild 2 von 2
    • Use a flathead screwdriver or a 1/4-inch socket to remove the two screws holding the shield plate to the draft inducer assembly.
    • Remove the plate and set it off to the side.
    • Be sure to keep track of all the screws and bolts!
  5. Draft Inducer Motor Replacement: Schritt 5, Bild 1 von 3 Draft Inducer Motor Replacement: Schritt 5, Bild 2 von 3 Draft Inducer Motor Replacement: Schritt 5, Bild 3 von 3
    • Use a 1/4-inch socket to remove the three mounting bolts securing the draft inducer assembly to the furnace.
    • Support the motor and assembly from the bottom and slowly remove it from the furnace.
  6. Draft Inducer Motor Replacement: Schritt 6, Bild 1 von 2 Draft Inducer Motor Replacement: Schritt 6, Bild 2 von 2
    • Use a flathead screwdriver or a small pry tool to carefully pry off the circular clip from the cooling fan.
    • Be careful not to apply a lot of pressure on the fan itself, since it's made of plastic and will break with enough force.
  7. Draft Inducer Motor Replacement: Schritt 7, Bild 1 von 3 Draft Inducer Motor Replacement: Schritt 7, Bild 2 von 3 Draft Inducer Motor Replacement: Schritt 7, Bild 3 von 3
    • Remove the cooling fan from the motor's driveshaft.
    • You may need to apply a decent amount of pressure and wiggle the fan in order to knock it loose.
  8. Draft Inducer Motor Replacement: Schritt 8, Bild 1 von 3 Draft Inducer Motor Replacement: Schritt 8, Bild 2 von 3 Draft Inducer Motor Replacement: Schritt 8, Bild 3 von 3
    • Flip the assembly over and use a 1/8-inch hex key to loosen the set screw securing the blower fan to the motor's driveshaft.
    • More than likely, the fan and set screw will be rusted and seized to the driveshaft. A few sprays of penetrating oil will help loosen it up.
  9. Draft Inducer Motor Replacement: Schritt 9, Bild 1 von 3 Draft Inducer Motor Replacement: Schritt 9, Bild 2 von 3 Draft Inducer Motor Replacement: Schritt 9, Bild 3 von 3
    • Remove the blower fan from the motor's driveshaft.
    • As with the cooling fan, you may need to apply a decent amount of pressure and wiggle the blower fan in order to remove it.
  10. Draft Inducer Motor Replacement: Schritt 10, Bild 1 von 3 Draft Inducer Motor Replacement: Schritt 10, Bild 2 von 3 Draft Inducer Motor Replacement: Schritt 10, Bild 3 von 3
    • Flip over the assembly and use a 1/4-inch socket to remove the three bolts securing the motor bracket to the motor plate.
    • Once the bolts are removed, flip the assembly back over and remove the motor bracket.
    • Once removed, take note of the motor's ground wire, which connects to one of the bracket bolts. Be sure to reconnect it during reassembly.
  11. Draft Inducer Motor Replacement: Schritt 11, Bild 1 von 2 Draft Inducer Motor Replacement: Schritt 11, Bild 2 von 2
    • Use a 1/4-inch socket to remove the two bolts securing the motor to the motor plate.
    • Remove the motor bracket.
  12. Draft Inducer Motor Replacement: Schritt 12, Bild 1 von 1
    • When installing the blower fan onto the new motor, be sure that the set screw on the blower fan lines up with the flat edge of the motor's driveshaft.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Craig Lloyd
35.418 Reputation
82 Anleitungen geschrieben
2 Kommentare
Thanks for the instructions, very helpful.
Do you know the Inducer motor part number?
Selvan Lingam - Antwort
Good morning, I need the whole unit ( motor, fan, blower fan, ) etc. This looks like same same unit I have but I can't find a model number for this to make sure I purchase the right one for my unit. I have a carrier weathermaker 8000vs looks exactly like the one here can someone please provide some helpful information thanks.
Joshua Thomas - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 27
Letzte 30 Tage: 147
Insgesamt: 21,906
