Zum Hauptinhalt wechseln
MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement
Was du brauchst
  1. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement, Access Door: Schritt 1, Bild 1 von 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement, Access Door: Schritt 1, Bild 2 von 2
    • With the case closed, place the Unibody top-side down on a flat surface.
    • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
  2. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 2, Bild 1 von 1
    • The access door should now be raised enough to lift it up and out of the Unibody.
  3. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement, Battery: Schritt 3, Bild 1 von 1
    • Be sure the access door release latch is vertical before proceeding.
    • Grab the translucent plastic tab and pull the battery up and out of the Unibody.
    • If the latch is depressed it will lock the battery in place.
  4. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement, Lower Case: Schritt 4, Bild 1 von 1
    • Remove the following eight screws securing the lower case to the chassis:
    • One 5.4 mm Phillips screw.
    • Three 14 mm Phillips screws.
    • Four 3.5 mm Phillips screws.
  5. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 5, Bild 1 von 1
    • Using both hands, lift and remove the lower case off the upper case.
  6. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement, Mid Wall: Schritt 6, Bild 1 von 1
    • Remove the following 5 screws securing the mid wall to the upper case:
    • Three 10.5 mm Phillips screws.
    • Two 3.7 mm Phillips screws.
  7. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 7, Bild 1 von 1
    • Lift the mid wall out of the upper case.
  8. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement, Logic Board: Schritt 8, Bild 1 von 1
    • Remove the following six screws securing both the right fan and the left fan to the logic board:
    • Two 3.2 mm Phillips screws.
  9. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 9, Bild 1 von 3 MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 9, Bild 2 von 3 MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 9, Bild 3 von 3
    • Use the tip of a spudger to lift the right fan connector straight up from its socket on the logic board.
    • Be sure to only pry up on the connector itself not on the socket or you may damage the machine.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • Remove the right fan from the case.
  10. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 10, Bild 1 von 3 MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 10, Bild 2 von 3 MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 10, Bild 3 von 3
    • Use the tip of a spudger to lift the left fan connector straight up from its socket on the logic board.
    • Remove the left fan from the case.
  11. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 11, Bild 1 von 1
    • Remove any adhesive from the camera cable connector.
    • Disconnect the camera cable by pulling the male end out of its socket, parallel to the logic board, do not lift it upwards.
  12. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 12, Bild 1 von 1
    • Use a spudger to carefully pry the optical drive connector straight up off its socket on the logic board.
  13. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 13, Bild 1 von 1
    • If necessary, peel off the foam bumper covering the subwoofer connector.
    • Using the flat end of a spudger, pry the subwoofer connector straight up off its socket on the logic board.
    • Be very careful. This connection is delicate, the socket can be easily broken off the logic board.
  14. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 14, Bild 1 von 1
    • Use the flat end of a spudger to pry the silver-colored hard drive cable connector straight up out of its socket on the logic board.
  15. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 15, Bild 1 von 1
    • Use a spudger to pry the trackpad connector straight up out of its socket on the logic board.
  16. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 16, Bild 1 von 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 16, Bild 2 von 2
    • Using the tip of a spudger, flip up the IR/sleep LED ribbon cable retaining flap.
    • Pull the IR/sleep LED ribbon cable straight out of its socket.
  17. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 17, Bild 1 von 1
    • Use a spudger to pry the battery indicator light connector straight up out of its socket on the logic board.
    • Pry up under the cable wires to avoid pulling the socket itself off of the logic board.
  18. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 18, Bild 1 von 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 18, Bild 2 von 2
    • Using the tip of a spudger, flip up the keyboard ribbon cable retaining flap.
    • Pull the keyboard ribbon cable straight out of its socket.
    • During reassembly, make sure to fully insert the keyboard ribbon cable back into the ZIF socket.
  19. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 19, Bild 1 von 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 19, Bild 2 von 2
    • Using the tip of a spudger, flip up the express card cage ribbon cable retaining flap.
    • Pull the express card cage ribbon cable straight out of its socket.
  20. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 20, Bild 1 von 1
    • Using the flat end of a spudger, pry the microphone cable connector straight up out of its socket on the logic board.
  21. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 21, Bild 1 von 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 21, Bild 2 von 2
    • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-in side of the computer.
    • Pull the display data cable connector straight away from its socket.
    • When disconnecting the display data cable, do not pull on the black tab secured to the cable lock. We recommend wiggling the cable while applying tension to slowly "walk" the connector out of its socket.
    • Make sure the display data cable is placed correctly in its socket during reassembly. Failure to do so will result in a partially visible display or no display image at all.
  22. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 22, Bild 1 von 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 22, Bild 2 von 2
    • Locate the keyboard backlight ribbon cable (near the left fan space).
    • Using the tip of a spudger, flip up the keyboard backlight ribbon cable retaining flap.
    • Pull the keyboard backlight ribbon cable straight out of its socket.
  23. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 23, Bild 1 von 1
    • Remove seven 3.2 mm Phillips screws securing the logic board to the upper case.
    • Do not remove the logic board yet! There are connectors attached to the underside of the logic board that must first be disconnected.
  24. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 24, Bild 1 von 1
    • Remove two 7 mm Phillips screws securing the DC-in board to the upper case.
    • Note: This step is not completely necessary, but it will make it easier to disconnect the cable that is connected to the DC-in board.
  25. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 25, Bild 1 von 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 25, Bild 2 von 2
    • Remove two 3.5 mm Phillips screws securing the bottom case clip to the upper case.
    • Lift the bottom case clip out of the upper case.
    • Some MacBook Pro Unibodies do not have a bottom case clip and do not require this step.
  26. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 26, Bild 1 von 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 26, Bild 2 von 2
    • Carefully lift the logic board assembly from the left side and work it out of the upper case, minding the port side that may get caught during removal.
    • Do not entirely remove the logic board yet!
    • Ensure that the logic board is free from all connections to the upper case (except the battery connector) before proceeding.
    • During reassembly, ensure all connectors and cables are not placed underneath the logic board. Some of the ribbon cables are very thin and fragile.
  27. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 27, Bild 1 von 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 27, Bild 2 von 2
    • Lift the logic board enough to grab the battery connector and pull it straight away from its socket on the logic board.
    • Lift the logic board assembly out of the upper case.
  28. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement, Trackpad: Schritt 28, Bild 1 von 1
    • Deroute the camera data cable from its channel on the optical drive.
  29. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 29, Bild 1 von 3 MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 29, Bild 2 von 3 MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 29, Bild 3 von 3
    • Remove the following three Phillips screws securing the optical drive to the upper case:
    • Two 2.5 mm Phillips screws.
    • One 3.5 mm Phillips screw.
    • Lift the optical drive out of the upper case.
  30. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 30, Bild 1 von 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 30, Bild 2 von 2
    • Remove the following four screws securing the subwoofer and right speaker to the upper case:
    • One 2.6 mm Phillips screw.
    • One 5.0 mm Phillips screw.
    • Lift the subwoofer and right speaker assembly out of the upper case.
  31. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 31, Bild 1 von 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 31, Bild 2 von 2
    • Insert the flat end of a spudger underneath the trackpad ribbon cable and gently peel it up from the adhesive securing it to the upper case.
  32. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 32, Bild 1 von 1
    • Open your MacBook Pro and set it on a table as shown.
  33. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 33, Bild 1 von 1
    • While holding the edge of the trackpad closest to the logic board with one hand, remove the six 1.3 mm Phillips screws securing the two brackets to the trackpad.
  34. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 34, Bild 1 von 3 MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 34, Bild 2 von 3 MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 34, Bild 3 von 3
    • While holding the trackpad in place with your left hand, fold the top of the trackpad ribbon cable down with your right hand so that it fits through its slot in the upper case.
    • Feed the ribbon cable through the slot as you push the portion of the trackpad closest to the keyboard out of the upper case.
  35. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 35, Bild 1 von 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 35, Bild 2 von 2
    • With the cable free, remove the trackpad from the upper case.
  36. MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 36, Bild 1 von 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 Trackpad Replacement: Schritt 36, Bild 2 von 2
    • To replace the trackpad brackets, you must first remove the black covers that hold them to the upper case.
    • Remove the four 2.7 mm Phillips screws from the two trackpad bracket covers.
    • The small metal brackets may fall off once the covers are removed. When replacing them it is easiest to set them in place with a pair of tweezers.
Abschluss
55 weitere Nutzer:innen haben diese Anleitung absolviert.
David Hodson
150.503 Reputation
127 Anleitungen geschrieben
3 Kommentare
I did it! But the mouse isn't working :( I double checked the trackpad connection and restarted. Still no movement. Maybe it's a bad trackpad? Anyone have any other ideas?
B Sward - Antwort
Beatifully documented "way to go!". Thanks David
Macsteff - Antwort
What size is the tri-wing screwdriver needed to adjust the trackpad on this model?
Mario Yiannakou - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 58
Insgesamt: 43,743
