Zum Hauptinhalt wechseln
Was du brauchst
Einführungsvideo
Dieser Teardown ist keine Reparaturanleitung. Um dein OnePlus 7 Pro zu reparieren, verwende unsere Fehlerbehebungsseite.
    Fazit
    • The battery can be removed first, once you open the phone. It’s only lightly adhered and comes with a pull tab for easy removal.
    • Many components are modular and can be individually replaced.
    • Display replacements, which are the most common repairs, are not prioritized in the design. (You have to completely disassemble the phone to swap out your screen.)
    • While the Front Facing Camera’s new pop up ability is really cool, the added mechanical element makes it more likely to wear out and more complicated to replace.
    • The primary access point for all repairs, the rear panel, is firmly glued in place.
    Reparierbarkeits-Index
    4
    Reparierbarkeit 4 von 10
    (10 ist am einfachsten zu reparieren)
6 Kommentare
What is the best way to get rid of slider?
Can it be cut from outside w/o unglue back cover?
Bob Monkas - Antwort
Slider? Do you mean the pop up camera? If so, removing it is major surgery, cannot be done from the outside.
Forge -
Can I replace the 256 memory module? Need to salvage some things on it.
vishal.shah.tx - Antwort
OnePlus 7 pro 8/256
Anita Jajoriya -
do i need to remove the pop up camera if i want to change the screen?
romain.collet - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 60
Letzte 30 Tage: 322
Insgesamt: 69,565
