Zum Hauptinhalt wechseln
Toshiba Satellite E105-S1602 Keyboard Replacement
Was du brauchst
  1. Toshiba Satellite E105-S1602 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Satellite E105-S1602 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Slide both of the latches to the outside to release the battery.
  2. Toshiba Satellite E105-S1602 Keyboard Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite E105-S1602 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Pull the battery out by lifting the battery cover away from the laptop.
  3. Toshiba Satellite E105-S1602 Keyboard Replacement, Keyboard: Schritt 3, Bild 1 von 3 Toshiba Satellite E105-S1602 Keyboard Replacement, Keyboard: Schritt 3, Bild 2 von 3 Toshiba Satellite E105-S1602 Keyboard Replacement, Keyboard: Schritt 3, Bild 3 von 3
    • Flip the computer over and insert the plastic opening tool under the plastic strip at the top of the keyboard.
    • Pry the top plastic strip from the top of the keyboard.
    • Peel the strip completely away from the keyboard.
  4. Toshiba Satellite E105-S1602 Keyboard Replacement: Schritt 4, Bild 1 von 2 Toshiba Satellite E105-S1602 Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Using your Phillips #00, unscrew the two 4.80mm screws at the top of the keyboard.
  5. Toshiba Satellite E105-S1602 Keyboard Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite E105-S1602 Keyboard Replacement: Schritt 5, Bild 2 von 2
    • When removing the keyboard, be careful not to rip the ribbon cable connecting the keyboard to the computer, to avoid damaging it.
    • Flip the keyboard up from the bottom in order to see the two ribbons connecting it to the motherboard.
  6. Toshiba Satellite E105-S1602 Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Using the plastic opening tools, pop out the ribbon cable from the rest of the computer.
  7. Toshiba Satellite E105-S1602 Keyboard Replacement: Schritt 7, Bild 1 von 1
    • Using the plastic opening tools, pop out the second ribbon cable from the rest of the computer.
  8. Toshiba Satellite E105-S1602 Keyboard Replacement: Schritt 8, Bild 1 von 2 Toshiba Satellite E105-S1602 Keyboard Replacement: Schritt 8, Bild 2 von 2
    • Completely remove the keyboard from the laptop by lifting up the part closest to the screen, and then gently pulling out the bottom half.
    • Keep the keyboard safe by storing it on a flat, non-metallic surface until needed.
Abschluss
Cal Poly, Team 17-21, Forte Winter 2013 Mitglied von Cal Poly, Team 17-21, Forte Winter 2013
CPSU-FORTE-W13S17G21
5 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 16
Insgesamt: 1,569
