Zum Hauptinhalt wechseln
Lexmark Intuition S505 Scanner Unit Replacement
Was du brauchst
  1. Lexmark Intuition S505 Scanner Unit Replacement, Duplex Unit: Schritt 1, Bild 1 von 1
    • Hold the button down with the flat end away from the printer. When you hear a click, the duplex unit can be removed from the printer.
  2. Lexmark Intuition S505 Scanner Unit Replacement: Schritt 2, Bild 1 von 2 Lexmark Intuition S505 Scanner Unit Replacement: Schritt 2, Bild 2 von 2
    • Remove the duplex unit from the back of the printer with the duplex unit facing up.
  3. Lexmark Intuition S505 Scanner Unit Replacement, Scanner Unit: Schritt 3, Bild 1 von 1
    • Locate the two screw holes that connect the two cylindrical extensions from the top portion of the scanner unit to the printer.
  4. Lexmark Intuition S505 Scanner Unit Replacement: Schritt 4, Bild 1 von 1
    • Unscrew the two size#6 (5-mm head) Phillips 1-mm screws connecting the scanner unit to the printer.
  5. Lexmark Intuition S505 Scanner Unit Replacement: Schritt 5, Bild 1 von 1
    • Raise and close the scanner unit to observe that the hinges lock in place when lifted.
  6. Lexmark Intuition S505 Scanner Unit Replacement: Schritt 6, Bild 1 von 2 Lexmark Intuition S505 Scanner Unit Replacement: Schritt 6, Bild 2 von 2
    • Firmly press the hinges inward toward the middle of the printer on both sides at the same time. The hinges should be easily lifted up and removed.
  7. Lexmark Intuition S505 Scanner Unit Replacement: Schritt 7, Bild 1 von 1
    • Locate the three screws connecting the plastic tray to the printer.
  8. Lexmark Intuition S505 Scanner Unit Replacement: Schritt 8, Bild 1 von 1
    • Remove the three size#6 (5-mm head) Phillips 1-mm screws connecting the scanner unit to the printer.
  9. Lexmark Intuition S505 Scanner Unit Replacement: Schritt 9, Bild 1 von 1
    • Remove the plastic cover by unlocking the plastic hinges at the inside edges of the printer. Use a plastic opening tool or a tweezer to slowly move in between the crease around the printer to unlock it.
  10. Lexmark Intuition S505 Scanner Unit Replacement: Schritt 10, Bild 1 von 2 Lexmark Intuition S505 Scanner Unit Replacement: Schritt 10, Bild 2 von 2
    • Slowly raise, but do not remove the plastic cover with the scanner unit so that it exposes the three cables connecting the scanner unit to the printer.
  11. Lexmark Intuition S505 Scanner Unit Replacement: Schritt 11, Bild 1 von 1
    • Carefully unplug the pink cable.
  12. Lexmark Intuition S505 Scanner Unit Replacement: Schritt 12, Bild 1 von 1
    • Carefully unplug the gray data cable.
  13. Lexmark Intuition S505 Scanner Unit Replacement: Schritt 13, Bild 1 von 1
    • Carefully unplug the white ribbon data cable.
  14. Lexmark Intuition S505 Scanner Unit Replacement: Schritt 14, Bild 1 von 1
    • Locate the three ports for the cables from the scanner unit and make sure they are unplugged.
  15. Lexmark Intuition S505 Scanner Unit Replacement: Schritt 15, Bild 1 von 1
    • Remove the scanner unit with the plastic cover by lifting it up from the bottom portion of the printer.
    • Be careful with the paper tray and make sure it is evenly lifted through the rectangular hole in the plastic tray
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Raymond
45 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 18-38, Regan Winter 2013 Mitglied von Cal Poly, Team 18-38, Regan Winter 2013
CPSU-REGAN-W13S18G38
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 10
Insgesamt: 1,249
