Zum Hauptinhalt wechseln
Disassembling Canon Pixma MP480 Rear and Side Panel
Was du brauchst
  1. Disassembling Canon Pixma MP480 Rear and Side Panel, Rear and Side Panel: Schritt 1, Bild 1 von 2 Disassembling Canon Pixma MP480 Rear and Side Panel, Rear and Side Panel: Schritt 1, Bild 2 von 2
    • Remove the two 7.9 mm screws using a Phillips #1 screwdriver.
  2. Disassembling Canon Pixma MP480 Rear and Side Panel: Schritt 2, Bild 1 von 1
    • Lift up the back cover to remove it.
    • You may need to lift firmly as it requires quite a bit of force.
  3. Disassembling Canon Pixma MP480 Rear and Side Panel: Schritt 3, Bild 1 von 1
    • Open the front tray.
  4. Disassembling Canon Pixma MP480 Rear and Side Panel: Schritt 4, Bild 1 von 2 Disassembling Canon Pixma MP480 Rear and Side Panel: Schritt 4, Bild 2 von 2
    • Open the scanner compartment.
    • Make sure the blue lever locks into place to keep the compartment open.
  5. Disassembling Canon Pixma MP480 Rear and Side Panel: Schritt 5, Bild 1 von 2 Disassembling Canon Pixma MP480 Rear and Side Panel: Schritt 5, Bild 2 von 2
    • Remove the blue lever from its slot by pushing it back and twisting clockwise.
    • Close the scanner compartment and cover.
  6. Disassembling Canon Pixma MP480 Rear and Side Panel: Schritt 6, Bild 1 von 2 Disassembling Canon Pixma MP480 Rear and Side Panel: Schritt 6, Bild 2 von 2
    • Pry open the side cover with the plastic opening tool.
  7. Disassembling Canon Pixma MP480 Rear and Side Panel: Schritt 7, Bild 1 von 2 Disassembling Canon Pixma MP480 Rear and Side Panel: Schritt 7, Bild 2 von 2
    • Flip the printer over so that the bottom of the printer is facing you.
    • Use the plastic opening tool to remove the corner of the side panel from the plastic pin.
  8. Disassembling Canon Pixma MP480 Rear and Side Panel: Schritt 8, Bild 1 von 2 Disassembling Canon Pixma MP480 Rear and Side Panel: Schritt 8, Bild 2 von 2
    • Use the plastic opening tool to loosen the side panel from the bottom of the printer.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 19-41, Regan Winter 2013 Mitglied von Cal Poly, Team 19-41, Regan Winter 2013
CPSU-REGAN-W13S19G41
4 Mitglieder
6 Anleitungen geschrieben
2 Kommentare
Where is the rest of disassembly?
bill roberts - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 23
Insgesamt: 21,143
