Zum Hauptinhalt wechseln
PSP 2000 Speaker Replacement
Was du brauchst
  1. PSP 2000 Speaker Replacement, Battery: Schritt 1, Bild 1 von 3 PSP 2000 Speaker Replacement, Battery: Schritt 1, Bild 2 von 3 PSP 2000 Speaker Replacement, Battery: Schritt 1, Bild 3 von 3
    • Place PSP face down, so that the UMD Drive is facing upwards.
    • Locate the battery door and open.
    • Remove the battery from inside.
  2. PSP 2000 Speaker Replacement, Front Casing: Schritt 2, Bild 1 von 1
    • This step requires the removal of the warranty sticker. Removing the sticker will void the warranty. According to the FTC removing this will not void your warranty.
    • Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
    • Remove the sticker using the PSP Opening Tools.
    • Under the sticker is a 5mm Phillips screw needed in the next step.
  3. PSP 2000 Speaker Replacement: Schritt 3, Bild 1 von 2 PSP 2000 Speaker Replacement: Schritt 3, Bild 2 von 2
    • Remove four 5 mm Phillips from the case.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
  4. PSP 2000 Speaker Replacement: Schritt 4, Bild 1 von 2 PSP 2000 Speaker Replacement: Schritt 4, Bild 2 von 2
    • Remove the following screws from around the bezel:
    • Two 4 mm Phillips
    • One 5 mm Phillips
    • The two shorter 4 mm screws are on the top of the PSP; the longer 5 mm screw is on the bottom.
  5. PSP 2000 Speaker Replacement: Schritt 5, Bild 1 von 2 PSP 2000 Speaker Replacement: Schritt 5, Bild 2 von 2
    • Gently pry the front bezel away from the casing using a PSP opening tool.
    • Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
    • If you want to clean the control buttons or D-pad, you can easily pop them out once the faceplate is off and wipe them clean.
  6. PSP 2000 Speaker Replacement, Display: Schritt 6, Bild 1 von 3 PSP 2000 Speaker Replacement, Display: Schritt 6, Bild 2 von 3 PSP 2000 Speaker Replacement, Display: Schritt 6, Bild 3 von 3
    • Remove the home bar by gently prying on the left and right sides of it with the opening tools. Lift the bar out of the device.
    • A ribbon cable connects the home bar to the logic board. Be careful not to damage the cable when removing the bar.
  7. PSP 2000 Speaker Replacement: Schritt 7, Bild 1 von 3 PSP 2000 Speaker Replacement: Schritt 7, Bild 2 von 3 PSP 2000 Speaker Replacement: Schritt 7, Bild 3 von 3
    • With the home bar out of the way, gently pry up the display using the opening tools.
    • There is another ribbon cable attached to the bottom of the LCD. Be careful not to damage either of the connectors when removing.
    • Lift the black tabs of the ribbon cable connectors using a opening tool. Pull the ribbons out towards the bottom of the PSP to disconnect.
    • Gently lift out the display.
  8. PSP 2000 Speaker Replacement, Speaker: Schritt 8, Bild 1 von 2 PSP 2000 Speaker Replacement, Speaker: Schritt 8, Bild 2 von 2
    • Use the opening tools to press the tab on the left-hand side of the speaker to release it.
    • Be careful not to puncture the speaker in the process.
    • Remove the speaker by twisting it counter-clockwise (to the left, like a screw).
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
espinks
3.472 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 6-3, Maness Fall 2009 Mitglied von Cal Poly, Team 6-3, Maness Fall 2009
CPSU-MANESS-F09S6G3
5 Mitglieder
35 Anleitungen geschrieben
Ein Kommentar
What about the other speaker? How to replace?
felipeavatar - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 18
Letzte 30 Tage: 71
Insgesamt: 12,433
