Einleitung
RAM should be replaced if the computer has memory issues. This is sometimes the case when the computer won't boot, or simply runs too slow for comfort.
Was du brauchst
Turn off the computer.
Disconnect the charging cable from the computer.
Flip the computer upside down.
Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
Remove the seven 5.3 mm Phillips #1 screws holding the back panel in place.
Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly.
The computer should be open with many of the internal components shown. You can now access the hard drive, the RAM, and the keyboard.
Locate the RAM Sticks in the computer. They should be in the corner of the laptop.
Using a spudger, push one of the metal rods on either side of the RAM stick away from it until you hear a light clicking noise. Repeat this procedure on the other metal rod on the opposite side of the RAM stick.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
maine apne lenovo g560 laptop me crucial 4gb ram add kiya lekin mera system format nahi ho raha h. mujhe kya karna chahiye mujhe email kare. vikasmaddeshiya056@gmail.com
