Zum Hauptinhalt wechseln
Disassembling Midland X-tra Talk Radio LXT118 Circuit Board
Was du brauchst
  1. Disassembling Midland X-tra Talk Radio LXT118 Circuit Board, Batteries: Schritt 1, Bild 1 von 2 Disassembling Midland X-tra Talk Radio LXT118 Circuit Board, Batteries: Schritt 1, Bild 2 von 2
    • First, apply pressure with your thumb on the top of the battery cover.
    • Next, pull down on the cover until it begins to slide.
  2. Disassembling Midland X-tra Talk Radio LXT118 Circuit Board: Schritt 2, Bild 1 von 1
    • Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
  3. Disassembling Midland X-tra Talk Radio LXT118 Circuit Board, Case: Schritt 3, Bild 1 von 1
    • Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
  4. Disassembling Midland X-tra Talk Radio LXT118 Circuit Board: Schritt 4, Bild 1 von 1
    • Detach back part of the case by gently lifting up.
  5. Disassembling Midland X-tra Talk Radio LXT118 Circuit Board, Midland X-tra Talk Radio LXT118: Schritt 5, Bild 1 von 1
    • Remove the old or broken circuit board from the front case by carefully separating it from the back.
    • Clip the red and black wires at the base of the motherboard to completely separate it from the radio case. You should have 2 separate pieces.
Abschluss
To reassemble your device, follow these instructions in reverse order, from step 6 to 1.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 19-43, Regan Winter 2013 Mitglied von Cal Poly, Team 19-43, Regan Winter 2013
CPSU-REGAN-W13S19G43
3 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 14
Insgesamt: 903
