Zum Hauptinhalt wechseln
Toshiba Satellite E105-S1602 Wifi Card Replacement
Was du brauchst
  1. Toshiba Satellite E105-S1602 Wifi Card Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Satellite E105-S1602 Wifi Card Replacement, Battery: Schritt 1, Bild 2 von 2
    • Slide both of the latches to the outside to release the battery.
  2. Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 2, Bild 2 von 2
    • Pull the battery out by lifting the battery cover away from the laptop.
  3. Toshiba Satellite E105-S1602 Wifi Card Replacement, Keyboard: Schritt 3, Bild 1 von 3 Toshiba Satellite E105-S1602 Wifi Card Replacement, Keyboard: Schritt 3, Bild 2 von 3 Toshiba Satellite E105-S1602 Wifi Card Replacement, Keyboard: Schritt 3, Bild 3 von 3
    • Flip the computer over and insert the plastic opening tool under the plastic strip at the top of the keyboard.
    • Pry the top plastic strip from the top of the keyboard.
    • Peel the strip completely away from the keyboard.
  4. Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 4, Bild 1 von 2 Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 4, Bild 2 von 2
    • Using your Phillips #00, unscrew the two 4.80mm screws at the top of the keyboard.
  5. Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 5, Bild 2 von 2
    • When removing the keyboard, be careful not to rip the ribbon cable connecting the keyboard to the computer, to avoid damaging it.
    • Flip the keyboard up from the bottom in order to see the two ribbons connecting it to the motherboard.
  6. Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 6, Bild 1 von 1
    • Using the plastic opening tools, pop out the ribbon cable from the rest of the computer.
  7. Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 7, Bild 1 von 1
    • Using the plastic opening tools, pop out the second ribbon cable from the rest of the computer.
  8. Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 8, Bild 1 von 2 Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 8, Bild 2 von 2
    • Completely remove the keyboard from the laptop by lifting up the part closest to the screen, and then gently pulling out the bottom half.
    • Keep the keyboard safe by storing it on a flat, non-metallic surface until needed.
  9. Toshiba Satellite E105-S1602 Wifi Card Replacement, Front Panel: Schritt 9, Bild 1 von 2 Toshiba Satellite E105-S1602 Wifi Card Replacement, Front Panel: Schritt 9, Bild 2 von 2
    • Locate the four silver screws on the front panel.
    • Using the Phillips #0, unscrew to remove all four 2.95mm silver screws.
  10. Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 10, Bild 1 von 2 Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 10, Bild 2 von 2
    • Flip the laptop over and locate all seven screws on the bottom of the laptop.
    • Unscrew all seven Philips#00 7.70mm screws.
  11. Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 11, Bild 1 von 2 Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 11, Bild 2 von 2
    • Locate and unscrew the three silver Philips #00 2.85mm screws inside the battery compartment.
    • Locate and unscrew the five black Philips #00 3.25mm screws inside the battery compartment.
  12. Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 12, Bild 1 von 2 Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 12, Bild 2 von 2
    • Rotate the laptop so the back faces you.
    • Locate the two black Philips #00 7.65 screws, one by each hinge, and remove.
  13. Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 13, Bild 1 von 3 Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 13, Bild 2 von 3 Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 13, Bild 3 von 3
    • Use the plastic opening tool to pry the top panel up from the base of the computer.
    • Slowly work your way around the computer with the plastic removing tool to make it easier to lift the top panel away from the base.
    • Carefully lift the top panel no more than six inches, as there are ribbon cables connecting the two pieces.
    • Disconnect ribbons, and slowly lift the top panel up, away from the base.
  14. Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 14, Bild 1 von 2 Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 14, Bild 2 von 2
    • Locate the ribbon cable from the motherboard.
    • Using plastic removing tools, pop the ribbon base from the motherboard.
  15. Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 15, Bild 1 von 2 Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 15, Bild 2 von 2
    • Locate the two plugs from the motherboard.
    • Using plastic opening tools, remove each plug from the motherboard.
  16. Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 16, Bild 1 von 2 Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 16, Bild 2 von 2
    • Locate the ribbon cable partially hidden under the front panel.
    • Using plastic opening tools, pop out the ribbon cable from the motherboard.
  17. Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 17, Bild 1 von 1
    • Make sure that all wires have been disconnected before proceeding to avoid damaging components.
    • Slowly lift the top panel away from the base of the computer.
    • Place the top panel away from the computer and keep in a flat non-metallic surface until needed.
  18. Toshiba Satellite E105-S1602 Wifi Card Replacement, Wifi Card: Schritt 18, Bild 1 von 1
    • Locate the WiFi card, which is directly beneath the disc drive.
  19. Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 19, Bild 1 von 3 Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 19, Bild 2 von 3 Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 19, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Locate the black wire and white wire connected to the WiFi card.
    • Using a pair of tweezers remove the wires by lifting them straight up away from the board.
    • For reassembly, note that the black wire connects to the top port, and the white wire to the bottom part.
  20. Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 20, Bild 1 von 2 Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 20, Bild 2 von 2
    • Locate and remove the two Philips #00 4.85 mm screws on the left of the WiFi card.
  21. Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 21, Bild 1 von 2 Toshiba Satellite E105-S1602 Wifi Card Replacement: Schritt 21, Bild 2 von 2
    • Be careful not to pull the WiFi card straight up, as you might damage components on the motherboard.
    • Grip the sides of the WiFi card and lift it up partially.
    • Gently pull the WiFi card away from the black plastic base to remove.
Abschluss
Cal Poly, Team 17-21, Forte Winter 2013 Mitglied von Cal Poly, Team 17-21, Forte Winter 2013
CPSU-FORTE-W13S17G21
5 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 18
Insgesamt: 1,825
