Zum Hauptinhalt wechseln
LG VX5200 Screen Replacement
Was du brauchst
  1. LG VX5200 Screen Replacement, Screen: Schritt 1, Bild 1 von 3 LG VX5200 Screen Replacement, Screen: Schritt 1, Bild 2 von 3 LG VX5200 Screen Replacement, Screen: Schritt 1, Bild 3 von 3
    • Pry the grey pieces of plastic off the corners of the screen with a spudger.
  2. LG VX5200 Screen Replacement: Schritt 2, Bild 1 von 2 LG VX5200 Screen Replacement: Schritt 2, Bild 2 von 2
    • Unscrew each of the four screws with a Phillips #00 Screwdriver.
    • These screws are the same size as the ones from the back casing, but are not the same size as the screw from the antenna.
  3. LG VX5200 Screen Replacement: Schritt 3, Bild 1 von 2 LG VX5200 Screen Replacement: Schritt 3, Bild 2 von 2
    • Close the phone after removing the screws.
    • Slide a spudger into the cracks in the top half of the phone's casing.
    • Wedge and lever the spudger to remove the casing.
    • Apply constant pressure to avoid cracking the plastic casing. This step can take a few minutes.
  4. LG VX5200 Screen Replacement: Schritt 4, Bild 1 von 3 LG VX5200 Screen Replacement: Schritt 4, Bild 2 von 3 LG VX5200 Screen Replacement: Schritt 4, Bild 3 von 3
    • Remove the chipboard from the screen by sliding a plastic spudger under the screen and lifting.
    • Use a plastic spudger to avoid short-circuiting the phone's electronics.
    • Gently lift the speaker out of the plastic casing using a plastic spudger.
    • Remove the small battery adjacent to the speaker with a plastic spudger.
  5. LG VX5200 Screen Replacement: Schritt 5, Bild 1 von 3 LG VX5200 Screen Replacement: Schritt 5, Bild 2 von 3 LG VX5200 Screen Replacement: Schritt 5, Bild 3 von 3
    • Slide and lever a plastic spudger between the screen and it's housing.
    • Avoid tearing the wires connecting the screen, the small battery and the speaker.
    • Remove the chip connecting the screen to the camera using your fingers.
Abschluss
jmarcum
16 Reputation
1 Anleitung geschrieben
Cal Poly, Team 9-18, Regan Fall 2009 Mitglied von Cal Poly, Team 9-18, Regan Fall 2009
CPSU-REGAN-F09S9G18
5 Mitglieder
2 Anleitungen geschrieben
Ein Kommentar
The “battery” beside the speaker isn’t the battery, it’s the phone vibrator. Still a good guide, however
Kaleb White - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 15
Insgesamt: 3,406
