Einleitung
Replacing the hard drive in your laptop is a beginner level repair, which can easily be executed.
Was du brauchst
Unscrew the two screws holding the panel over the hard drive using a Phillips screwdriver. The panel is located on the top right of the laptop's underside.
Remove the cover, firmly lifting from the indent. It is recommended that you leave the screws in the panel.
Remove the hard drive by pulling the tab upwards and sliding the hard drive out.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
