Zum Hauptinhalt wechseln
NETGEAR WGT624 v3 Antenna Replacement
Was du brauchst
  1. NETGEAR WGT624 v3 Antenna Replacement, Lower Case: Schritt 1, Bild 1 von 1
    • Turn the device so that the bottom is facing up.
  2. NETGEAR WGT624 v3 Antenna Replacement: Schritt 2, Bild 1 von 3 NETGEAR WGT624 v3 Antenna Replacement: Schritt 2, Bild 2 von 3 NETGEAR WGT624 v3 Antenna Replacement: Schritt 2, Bild 3 von 3
    • Use the plastic opening tool to carefully lift the rubber stops in each corner.
    • Do not completely remove the rubber stops, because they are difficult to replace.
  3. NETGEAR WGT624 v3 Antenna Replacement: Schritt 3, Bild 1 von 2 NETGEAR WGT624 v3 Antenna Replacement: Schritt 3, Bild 2 von 2
    • Unscrew the 4 11.8 mm T-8 Torx screws from each corner of the device.
  4. NETGEAR WGT624 v3 Antenna Replacement: Schritt 4, Bild 1 von 2 NETGEAR WGT624 v3 Antenna Replacement: Schritt 4, Bild 2 von 2
    • Lift the lower case straight up from the rest of the router.
  5. NETGEAR WGT624 v3 Antenna Replacement, Motherboard: Schritt 5, Bild 1 von 2 NETGEAR WGT624 v3 Antenna Replacement, Motherboard: Schritt 5, Bild 2 von 2
    • Remove the clear plastic casing by lifting it straight up from the router.
  6. NETGEAR WGT624 v3 Antenna Replacement: Schritt 6, Bild 1 von 2 NETGEAR WGT624 v3 Antenna Replacement: Schritt 6, Bild 2 von 2
    • Separate the motherboard from the top shell by lifting it straight up from the router.
  7. NETGEAR WGT624 v3 Antenna Replacement, Antenna: Schritt 7, Bild 1 von 1
    • Turn the motherboard, so that the top is facing upwards.
    • Place the motherboard on a clean flat surface.
  8. NETGEAR WGT624 v3 Antenna Replacement: Schritt 8, Bild 1 von 2 NETGEAR WGT624 v3 Antenna Replacement: Schritt 8, Bild 2 von 2
    • Remove the yellow tape that holds the wire.
    • Make sure that you set the tape aside on a clean surface, so that it can be reused.
  9. NETGEAR WGT624 v3 Antenna Replacement: Schritt 9, Bild 1 von 3 NETGEAR WGT624 v3 Antenna Replacement: Schritt 9, Bild 2 von 3 NETGEAR WGT624 v3 Antenna Replacement: Schritt 9, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use tweezers to gently pull the metal bracket that connects the antenna to the motherboard.
    • The wire should now be completely separate from the motherboard.
  10. NETGEAR WGT624 v3 Antenna Replacement: Schritt 10, Bild 1 von 1
    • Extend the antenna away from the device, so that it becomes straight.
  11. NETGEAR WGT624 v3 Antenna Replacement: Schritt 11, Bild 1 von 3 NETGEAR WGT624 v3 Antenna Replacement: Schritt 11, Bild 2 von 3 NETGEAR WGT624 v3 Antenna Replacement: Schritt 11, Bild 3 von 3
    • Find the clips that hold the antenna onto the router.
    • Use one hand to push the clips in, while using your other hand to pull out the antenna. You may need to gently twist the antenna so it can separate from the hole.
    • The antenna may take considerable force to remove.
  12. NETGEAR WGT624 v3 Antenna Replacement: Schritt 12, Bild 1 von 1
    • Completely separate the antenna and wire from the rest of the device.
Abschluss
Cal Poly, Team 3-31, Amido Winter 2013 Mitglied von Cal Poly, Team 3-31, Amido Winter 2013
CPSU-AMIDO-W13S3G31
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 18
Insgesamt: 4,391
