Einleitung
Before rushing out to replace your iPhone SE Lightning Connector, try this simple cleaning option.
My iPhone SE Lightning Connector had been in for repair under warranty 3 times and clearly had never been replaced. During the "replacement" of my Lightning Connector, I could see the phone had never been opened.
Unfortunately, the "replacement" Lightning Connector didn’t work. So, thinking that I had nothing to lose, I set about trying to fix it and it worked!
Was du brauchst
Using the fine tweezers, carefully remove the build up of fluff and other debris from inside the Lightning Connector. I was really shocked how much was in there.
After having cleared out the inside of the Lightning Connector, carefully apply contact cleaner. It may not be a bad idea to mask off the rest of the phone before doing this. My Lightning Connector had been removed from the phone so it wasn't a problem I had to deal with.
When the contact cleaner has dried, you're ready to go.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
