Zum Hauptinhalt wechseln
How to 'repair' iPhone SE Lightning Connector
Was du brauchst
    • Using the fine tweezers, carefully remove the build up of fluff and other debris from inside the Lightning Connector. I was really shocked how much was in there.
    • After having cleared out the inside of the Lightning Connector, carefully apply contact cleaner. It may not be a bad idea to mask off the rest of the phone before doing this. My Lightning Connector had been removed from the phone so it wasn't a problem I had to deal with.
    • Do this outside if possible as contact cleaner can stink.
    • When the contact cleaner has dried, you're ready to go.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 39
Insgesamt: 2,441
