Zum Hauptinhalt wechseln
Samsung Galaxy S Vibrant Midframe Replacement
Was du brauchst
  1. Samsung Galaxy S Vibrant Midframe Replacement, Battery: Schritt 1, Bild 1 von 3 Samsung Galaxy S Vibrant Midframe Replacement, Battery: Schritt 1, Bild 2 von 3 Samsung Galaxy S Vibrant Midframe Replacement, Battery: Schritt 1, Bild 3 von 3
    • Locate the small slit on the bottom edge of the device between the back and front cases.
    • Pop the back case off by inserting your finger and pulling the case away from the phone.
    • If necessary (it shouldn't be), use the Plastic Opening Tools to pry the back case off.
  2. Samsung Galaxy S Vibrant Midframe Replacement: Schritt 2, Bild 1 von 2 Samsung Galaxy S Vibrant Midframe Replacement: Schritt 2, Bild 2 von 2
    • Remove the battery by pushing the bottom edge of the battery up and away from the phone
    • If you would prefer, you may use the Plastic Opening Tools for this step as well.
  3. Samsung Galaxy S Vibrant Midframe Replacement, Midframe: Schritt 3, Bild 1 von 1
    • Remove SIM card by pushing down and away from the slot, then pulling it out toward the bottom edge of the phone.
  4. Samsung Galaxy S Vibrant Midframe Replacement: Schritt 4, Bild 1 von 1
    • Remove the seven 4.5 mm Phillips #00 screws along the perimeter of the phone.
  5. Samsung Galaxy S Vibrant Midframe Replacement: Schritt 5, Bild 1 von 3 Samsung Galaxy S Vibrant Midframe Replacement: Schritt 5, Bild 2 von 3 Samsung Galaxy S Vibrant Midframe Replacement: Schritt 5, Bild 3 von 3
    • Staring near the power button, use a plastic opening tool to disengage the plastic clips securing the midframe.
    • Work carefully, and disengage all of the clips before removing the midframe.
    • The power button and the volume control button on the sides of the phone will fall out when the midframe is removed.
  6. Samsung Galaxy S Vibrant Midframe Replacement: Schritt 6, Bild 1 von 2 Samsung Galaxy S Vibrant Midframe Replacement: Schritt 6, Bild 2 von 2
    • Slide the SD card out of its slot.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 18-37, Regan Winter 2013 Mitglied von Cal Poly, Team 18-37, Regan Winter 2013
CPSU-REGAN-W13S18G37
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,545
