Einleitung
Use this guide to remove the front casing and to access the keypad.
Was du brauchst
Apply downward pressure to the top of the battery panel while pulling down to slide it off the phone.
Locate the grooves on the sides of the battery near the bottom of the phone. Use your fingers to pull the battery up and out of the phone.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use the spudger to pry the two plastic caps out of the top corners of the phone casing.
Insert the plastic opening tool in the gap between the back panel and rest of the body.
Slide the tool along the edges until the two pieces come apart.
Pry apart the plastic tabs along the edges of the phone.
Separate the front panel from the main body of the phone using your fingers.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
