Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein BlackBerry 8700c zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. BlackBerry 8700c Teardown, BlackBerry 8700c Teardown: Schritt 1, Bild 1 von 1
    • In this first step you will remove the battery cover by pushing down on the button on the cover and sliding towards the bottom of the phone.
    • To do this unscrew all four T6 screws
    • Once this is done gently remove the back cover of the phone by pulling first from the bottom towards you, then from the top upwards.
  2. BlackBerry 8700c Teardown: Schritt 2, Bild 1 von 1
    • To remove the battery, place your fingernail in the slot at the top right of the battery and pull up.
  3. BlackBerry 8700c Teardown: Schritt 3, Bild 1 von 3 BlackBerry 8700c Teardown: Schritt 3, Bild 2 von 3 BlackBerry 8700c Teardown: Schritt 3, Bild 3 von 3
    • Next, remove the back portion of the phone by removing four T6 Screws.
    • Once the screws have been removed, firmly grab the back cover and pull back from the front cover.
  4. BlackBerry 8700c Teardown: Schritt 4, Bild 1 von 2 BlackBerry 8700c Teardown: Schritt 4, Bild 2 von 2
    • To remove the middle portion of the phone you will again remove four T6 screws.
    • Follow the removal of the screws, you can now pull the front face plate away from the middle portion.
  5. BlackBerry 8700c Teardown: Schritt 5, Bild 1 von 2 BlackBerry 8700c Teardown: Schritt 5, Bild 2 von 2
    • Follow the removal of the screws, you can now pull the middle portion away from the main logic board.
    • Next, hold the logic board and remove the front face plate of the phone
  6. BlackBerry 8700c Teardown: Schritt 6, Bild 1 von 2 BlackBerry 8700c Teardown: Schritt 6, Bild 2 von 2
    • When the front face plate has been pulled away, be sure to grab the keypad as it may fall out.
  7. BlackBerry 8700c Teardown: Schritt 7, Bild 1 von 2 BlackBerry 8700c Teardown: Schritt 7, Bild 2 von 2
    • Next, use a metal spudger to unhook the earpiece from the inside of the front panel.
  8. BlackBerry 8700c Teardown: Schritt 8, Bild 1 von 3 BlackBerry 8700c Teardown: Schritt 8, Bild 2 von 3 BlackBerry 8700c Teardown: Schritt 8, Bild 3 von 3
    • Using a metal spudger, push back on the four clips holding the LCD screen to the logic board.
    • Next gradually pull the screen away from the board so that none of the clips are engaged.
    • Last, use a metal spudger to push back on the clip locking in the ribbon cable for the screen.
  9. BlackBerry 8700c Teardown: Schritt 9, Bild 1 von 1
    • The screen is now fully detached, and the phone is completely disassembled.
k3nt
42 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 18-4, Maness Fall 2009 Mitglied von Cal Poly, Team 18-4, Maness Fall 2009
CPSU-MANESS-F09S18G4
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 20
Insgesamt: 6,563
