Einleitung
Replacing this antenna is about the easiest repair you can make to your Nexus Q
Was du brauchst
Squeeze and pull to pop the cap off of the Nexus Q.
Disconnect the taoglas Wi-Fi Dual Band Antenna by prying with a spudger.
Once the antenna is disconnected, simply pull it off the outside of the inner dome.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
