Zum Hauptinhalt wechseln
Sony Bloggie 3D Player USB Drive Replacement
Was du brauchst
  1. Sony Bloggie 3D Player USB Drive Replacement, Front Cover: Schritt 1, Bild 1 von 1
    • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  2. Sony Bloggie 3D Player USB Drive Replacement: Schritt 2, Bild 1 von 2 Sony Bloggie 3D Player USB Drive Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool to pry the cover open.
    • After the the cover is partly open as shown, remove the cover with your hands.
  3. Sony Bloggie 3D Player USB Drive Replacement, Back Cover: Schritt 3, Bild 1 von 2 Sony Bloggie 3D Player USB Drive Replacement, Back Cover: Schritt 3, Bild 2 von 2
    • Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
  4. Sony Bloggie 3D Player USB Drive Replacement: Schritt 4, Bild 1 von 2 Sony Bloggie 3D Player USB Drive Replacement: Schritt 4, Bild 2 von 2
    • Use a plastic opening tool to loosen the back cover off the device.
    • Once the back cover is loose, remove it gently by hand.
  5. Sony Bloggie 3D Player USB Drive Replacement, USB Drive: Schritt 5, Bild 1 von 2 Sony Bloggie 3D Player USB Drive Replacement, USB Drive: Schritt 5, Bild 2 von 2
    • Once the back cover is removed, by using the opening tool, remove the following screws using a Phillips #00 screwdriver.
    • Two 4.0mm Phillips #00 screws
    • One 8.0mm Phillips #00 screw
    • One 9.5mm Phillips #00 screw
  6. Sony Bloggie 3D Player USB Drive Replacement: Schritt 6, Bild 1 von 2 Sony Bloggie 3D Player USB Drive Replacement: Schritt 6, Bild 2 von 2
    • Using a spudger, remove the clips of the metal casing from each end of the USB drive.
  7. Sony Bloggie 3D Player USB Drive Replacement: Schritt 7, Bild 1 von 2 Sony Bloggie 3D Player USB Drive Replacement: Schritt 7, Bild 2 von 2
    • Carefully lift the USB drive off of the peg that it is attached to.
  8. Sony Bloggie 3D Player USB Drive Replacement: Schritt 8, Bild 1 von 1
    • Now that the USB component is on its own, untangle the ribbon from inside the device.
  9. Sony Bloggie 3D Player USB Drive Replacement: Schritt 9, Bild 1 von 1
    • Now remove the ZIF connector from the device using a pair of tweezers.
Abschluss
Craig Sweet
1 Reputation
1 Anleitung geschrieben
Cal Poly, Team 7-12, Maness Winter 2013 Mitglied von Cal Poly, Team 7-12, Maness Winter 2013
CPSU-MANESS-W13S7G12
5 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 486
