Zum Hauptinhalt wechseln
Nexus 4 Plastic Midframe Replacement
Was du brauchst
  1. Nexus 4 Plastic Midframe Replacement, Back Cover: Schritt 1, Bild 1 von 2 Nexus 4 Plastic Midframe Replacement, Back Cover: Schritt 1, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    SIM Card Eject Tool
    $2.99
    Kaufen
    • Power off the phone, by long-pressing the power button and touching Power off.
    • Remove the SIM tray using the SIM Card Eject Tool.
    • This step is required in order to remove the back case.
  2. Nexus 4 Plastic Midframe Replacement: Schritt 2, Bild 1 von 1
    T5 Torx Screwdriver
    $5.49
    Kaufen
  3. Nexus 4 Plastic Midframe Replacement: Schritt 3, Bild 1 von 3 Nexus 4 Plastic Midframe Replacement: Schritt 3, Bild 2 von 3 Nexus 4 Plastic Midframe Replacement: Schritt 3, Bild 3 von 3
    • Gently open the back case by prying along the edge of the cover, starting at a corner of the phone and circling around the phone using a plastic opening tool.
    • The opening process may take a few minutes. The plastic will make a light snapping noise as the back cover separates from the rest of the phone.
  4. Nexus 4 Plastic Midframe Replacement, Battery: Schritt 4, Bild 1 von 2 Nexus 4 Plastic Midframe Replacement, Battery: Schritt 4, Bild 2 von 2
    • Remove the two 1.8 mm Phillips screws holding down the battery connector.
    • Using a plastic opening tool, disconnect the battery cable from its socket on the motherboard.
  5. Nexus 4 Plastic Midframe Replacement, Battery removal: Schritt 5, Bild 1 von 2 Nexus 4 Plastic Midframe Replacement, Battery removal: Schritt 5, Bild 2 von 2
    Plastic Cards
    $2.99
    Kaufen
    • Remove the blue tape that secures the white antenna cable to the battery.
    • Using a spudger, carefully disconnect the white antenna cable.
    • Carefully pry the battery out with a Plastic Opening Tool, starting at the top left-hand corner and working down towards the bottom right-hand corner.
    • If necessary, you can also use a plastic card to separate the battery from the metal midframe.
    • The battery is securely glued to the phone. When reinstalling the battery, press the battery firmly against the adhesive strip.
  6. Nexus 4 Plastic Midframe Replacement, Plastic Midframe: Schritt 6, Bild 1 von 3 Nexus 4 Plastic Midframe Replacement, Plastic Midframe: Schritt 6, Bild 2 von 3 Nexus 4 Plastic Midframe Replacement, Plastic Midframe: Schritt 6, Bild 3 von 3
    • Remove the nine 4.6 mm Phillips #000 screws. Gently lift out the plastic cover.
    • The midframe is held in with two clips, one at either side. Use a plastic spudger to release each side and gently lift up and away.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Kaitlyn Jones
4.952 Reputation
8 Anleitungen geschrieben
Cal Poly, Team 3-32, Amido Winter 2013 Mitglied von Cal Poly, Team 3-32, Amido Winter 2013
CPSU-AMIDO-W13S3G32
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 11,015
