Einleitung
Use this guide to remove the frame from the screen on your OLPC XO 4.0 Touch.
Was du brauchst
Pull the lock tabs towards the green outer edges of the laptop.
Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
Rotate the screen 180° and remove the other two screws.
Remove the green side panel by pressing down on the small green button on the top and sliding the panel up.
Repeat the step above for the panel on the other side.
Gently lift up the lower part of the frame and pull it down to free the screen frame.
Lift the black connector and pull the ribbon cable out by the purple tab, freeing the frame.
