Zum Hauptinhalt wechseln
Lenovo ThinkPad X1 Extreme Docking Station Replacement
Was du brauchst
  1. Lenovo ThinkPad X1 Extreme Docking Station Replacement, Back Cover: Schritt 1, Bild 1 von 3 Lenovo ThinkPad X1 Extreme Docking Station Replacement, Back Cover: Schritt 1, Bild 2 von 3 Lenovo ThinkPad X1 Extreme Docking Station Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme Docking Station Replacement, Speakers: Schritt 2, Bild 1 von 1
    • Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
  3. Lenovo ThinkPad X1 Extreme Docking Station Replacement: Schritt 3, Bild 1 von 1
    • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Set the speaker modules out of the way.
  4. Lenovo ThinkPad X1 Extreme Docking Station Replacement, Battery: Schritt 4, Bild 1 von 3 Lenovo ThinkPad X1 Extreme Docking Station Replacement, Battery: Schritt 4, Bild 2 von 3 Lenovo ThinkPad X1 Extreme Docking Station Replacement, Battery: Schritt 4, Bild 3 von 3
    • Use tweezers to peel the plastic cover off the connector.
    • Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
  5. Lenovo ThinkPad X1 Extreme Docking Station Replacement: Schritt 5, Bild 1 von 1
    • Lift the battery out of the frame and remove it from the device.
  6. Lenovo ThinkPad X1 Extreme Docking Station Replacement, Fan: Schritt 6, Bild 1 von 3 Lenovo ThinkPad X1 Extreme Docking Station Replacement, Fan: Schritt 6, Bild 2 von 3 Lenovo ThinkPad X1 Extreme Docking Station Replacement, Fan: Schritt 6, Bild 3 von 3
    • Unscrew the 3mm screw holding down the wireless adapter using a Phillips #00 screwdriver.
    • Slide the adapter out of its connector.
    • Detach the black and gray cables and separate them from the frame of the fan by gently pulling upwards.
  7. Lenovo ThinkPad X1 Extreme Docking Station Replacement: Schritt 7, Bild 1 von 2 Lenovo ThinkPad X1 Extreme Docking Station Replacement: Schritt 7, Bild 2 von 2
    • Unlatch and remove the cable connecting to the frame of the fan by flipping the thin black tab up.
    • Separate the cable from the frame of the fan.
  8. Lenovo ThinkPad X1 Extreme Docking Station Replacement: Schritt 8, Bild 1 von 2 Lenovo ThinkPad X1 Extreme Docking Station Replacement: Schritt 8, Bild 2 von 2
    • Loosen the five screws connecting the fan to the motherboard using a Philips #00 head screwdriver.
    • These screws will not come out and will stay connected to the fan.
  9. Lenovo ThinkPad X1 Extreme Docking Station Replacement: Schritt 9, Bild 1 von 3 Lenovo ThinkPad X1 Extreme Docking Station Replacement: Schritt 9, Bild 2 von 3 Lenovo ThinkPad X1 Extreme Docking Station Replacement: Schritt 9, Bild 3 von 3
    • Gently disconnect the two cables located on right and left side of the fan.
    • To identify these, they are labeled "FANR1" and FANL2" on the motherboard.
    • Lift the fan up and out and remove it from the device.
  10. Lenovo ThinkPad X1 Extreme Docking Station Replacement, Motherboard: Schritt 10, Bild 1 von 3 Lenovo ThinkPad X1 Extreme Docking Station Replacement, Motherboard: Schritt 10, Bild 2 von 3 Lenovo ThinkPad X1 Extreme Docking Station Replacement, Motherboard: Schritt 10, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove the five 4 mm screws below the charging port.
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws.
    • Use a Phillips #00 screwdriver to remove the two 5 mm screws securing a silver plate on the charging port, in the top-right.
    • Remove the silver plate on top of the charging port.
  11. Lenovo ThinkPad X1 Extreme Docking Station Replacement: Schritt 11, Bild 1 von 3 Lenovo ThinkPad X1 Extreme Docking Station Replacement: Schritt 11, Bild 2 von 3 Lenovo ThinkPad X1 Extreme Docking Station Replacement: Schritt 11, Bild 3 von 3
    • Disconnect all the ribbon wires from the motherboard.
    • All ribbon wires can be disconnected by flipping up the thin black tab at their connection points, and pulling the ribbon out.
  12. Lenovo ThinkPad X1 Extreme Docking Station Replacement: Schritt 12, Bild 1 von 3 Lenovo ThinkPad X1 Extreme Docking Station Replacement: Schritt 12, Bild 2 von 3 Lenovo ThinkPad X1 Extreme Docking Station Replacement: Schritt 12, Bild 3 von 3
    • Disconnect the black attachment at the top right corner of the motherboard.
    • Insert the SIM eject bit into the small hole on the top and apply a small amount of pressure to release the clip.
    • While maintaining pressure, gently pull on the wire that is connected to it to remove it.
  13. Lenovo ThinkPad X1 Extreme Docking Station Replacement: Schritt 13, Bild 1 von 1
    • Gently lift the motherboard out of the computer.
  14. Lenovo ThinkPad X1 Extreme Docking Station Replacement, Docking Station: Schritt 14, Bild 1 von 1
    • Once you have the motherboard removed, you now have access to the docking stations.
  15. Lenovo ThinkPad X1 Extreme Docking Station Replacement: Schritt 15, Bild 1 von 2 Lenovo ThinkPad X1 Extreme Docking Station Replacement: Schritt 15, Bild 2 von 2
    • Gently push the docking station towards the center of the motherboard, lift up to release a lock, then pull it out to remove it from the device.
Abschluss
Cal Poly, Team S7-G3, Regan Winter 2020 Mitglied von Cal Poly, Team S7-G3, Regan Winter 2020
CPSU-REGAN-W20S7G3
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 810
