Zum Hauptinhalt wechseln
Braun Oral-B Sonic Complete 4729 Battery replacement
Was du brauchst
  1. Braun Oral-B Sonic Complete 4729 Battery replacement, Battery: Schritt 1, Bild 1 von 3 Braun Oral-B Sonic Complete 4729 Battery replacement, Battery: Schritt 1, Bild 2 von 3 Braun Oral-B Sonic Complete 4729 Battery replacement, Battery: Schritt 1, Bild 3 von 3
    • Push the bottom of the toothbrush against the knob on the back of the charger. Turn counter clock wise and the bottom should pop off. Put the toothbrush top down on a hard surface and push the inner part out.
    • Be careful with the thin wires connecting the bottom cover to the circuit board.
  2. Braun Oral-B Sonic Complete 4729 Battery replacement: Schritt 2, Bild 1 von 3 Braun Oral-B Sonic Complete 4729 Battery replacement: Schritt 2, Bild 2 von 3 Braun Oral-B Sonic Complete 4729 Battery replacement: Schritt 2, Bild 3 von 3
    • Remove the old battery pack.
    • The Batteries are soldered to the circuit Board. You can use your soldering iron here if you like but i think its not really needed. And probably the minus is quite hard to work on because it lays under some other stuff (fig. 3; The circle marks the minus and the square the plus connection).
    • If you're not using a soldering iron you have to peel off the wire guard from the old batteries to remove them cause they are your connectors for the new batteries. The spring in the bottom cover provides enough tension to keep the battery in place and connected without soldering.
  3. Braun Oral-B Sonic Complete 4729 Battery replacement: Schritt 3, Bild 1 von 3 Braun Oral-B Sonic Complete 4729 Battery replacement: Schritt 3, Bild 2 von 3 Braun Oral-B Sonic Complete 4729 Battery replacement: Schritt 3, Bild 3 von 3
    • Insert new battery pack.
    • If you unsoldered the old battery from the circuit board you have to solder the wire guards from the new Battery pack to the circuit board.
    • Otherwise just insert the new battery pack and reassemble the toothbrush. I used a pice of cardboard to make sure the plus gets proper connection (fig. 1).
Ziellinie
5 weitere Nutzer:innen haben diese Anleitung absolviert.
ndjenny
1.799 Reputation
1 Anleitung geschrieben
15 Kommentare
what is the replacement battery and where can
I get it?
Ron - Antwort
Hello Ron,
if you put: " Sanyo 2/KR-600AE 2/3 A Cadnica NiCd Battery Pack 2,4 V " into a search machine you should be able to find a replacement battery for this type.
At least thets how i got mine...
Kind regards Andy
ndjenny -
Do you need to buy 2 of these batteries? It looks like two separate batteries end to end.
Rob - Antwort
sorry for the late reply. No you don't need two batteries. Actually its a 2/3 A battery that means its 2/3 as long as a full A-size battery. in my case they delivered two 1/3 A batteries in one shrinking wrap but there are also 2/3 A batteries in one piece.
ndjenny -
I /think/ any "2/3 A" size battery should work - I've ordered some NiMH ones with nearly double capacity - I anticipate that these will hold more, but take longer to charge up.
Chris Murphy - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 25
Letzte 30 Tage: 73
Insgesamt: 42,365
