Zum Hauptinhalt wechseln
Playstation 3 Motherboard Enclosure Replacement
Archivierte Anleitung
Diese Anleitung wurde ausschließlich für historische Zwecke erhalten. Verwende die aktualisierte Version dieser Anleitung, um deine Reparatur durchzuführen.
Was du brauchst
  1. Playstation 3 Motherboard Enclosure Replacement, Top Cover: Schritt 1, Bild 1 von 2 Playstation 3 Motherboard Enclosure Replacement, Top Cover: Schritt 1, Bild 2 von 2
    • Remove the rubber screw cover near the hard drive cover with a spudger.
  2. Playstation 3 Motherboard Enclosure Replacement: Schritt 2, Bild 1 von 1
    • Remove the screw holding the top cover in place with a Torx T10 screwdriver.
  3. Playstation 3 Motherboard Enclosure Replacement: Schritt 3, Bild 1 von 2 Playstation 3 Motherboard Enclosure Replacement: Schritt 3, Bild 2 von 2
    • Slide the top cover down about half an inch.
    • Lift the cover off of the PS3.
  4. Playstation 3 Motherboard Enclosure Replacement: Schritt 4, Bild 1 von 2 Playstation 3 Motherboard Enclosure Replacement: Schritt 4, Bild 2 von 2
    • Remove the seven screws in the top cover with a Phillips #2 screwdriver.
    • One of the screws is shorter than the others. The short screw is marked in yellow.
  5. Playstation 3 Motherboard Enclosure Replacement: Schritt 5, Bild 1 von 3 Playstation 3 Motherboard Enclosure Replacement: Schritt 5, Bild 2 von 3 Playstation 3 Motherboard Enclosure Replacement: Schritt 5, Bild 3 von 3
    • You can now lift off the top cover.
  6. Playstation 3 Motherboard Enclosure Replacement, Power Supply: Schritt 6, Bild 1 von 2 Playstation 3 Motherboard Enclosure Replacement, Power Supply: Schritt 6, Bild 2 von 2
    • Unplug the white wires connected to the wireless board. There are two sets of wires: one set in the front, one in the back.
    • Push down the tab on the connector to disconnect the wires.
    • Remove the two screws on the front of the power supply.
  7. Playstation 3 Motherboard Enclosure Replacement: Schritt 7, Bild 1 von 1
    • Remove the screws on the back of the power supply with a Phillips #2 screwdriver.
  8. Playstation 3 Motherboard Enclosure Replacement: Schritt 8, Bild 1 von 2 Playstation 3 Motherboard Enclosure Replacement: Schritt 8, Bild 2 von 2
    • Remove the power supply by lifting it straight up.
  9. Playstation 3 Motherboard Enclosure Replacement, Motherboard Enclosure: Schritt 9, Bild 1 von 2 Playstation 3 Motherboard Enclosure Replacement, Motherboard Enclosure: Schritt 9, Bild 2 von 2
    • Unplug the optical drive power cable.
    • Detach the ribbon cable that connects the optical drive to the motherboard.
    • Set the optical drive aside.
  10. Playstation 3 Motherboard Enclosure Replacement: Schritt 10, Bild 1 von 2 Playstation 3 Motherboard Enclosure Replacement: Schritt 10, Bild 2 von 2
    • Remove three screws (Phillips #2) from the wireless board and antenna.
    • Detach the ribbon cable that connects the wireless board to the motherboard.
  11. Playstation 3 Motherboard Enclosure Replacement: Schritt 11, Bild 1 von 1
    • Remove nine screws (Phillips #2) from the perimeter of the metal plate covering the motherboard.
  12. Playstation 3 Motherboard Enclosure Replacement: Schritt 12, Bild 1 von 3 Playstation 3 Motherboard Enclosure Replacement: Schritt 12, Bild 2 von 3 Playstation 3 Motherboard Enclosure Replacement: Schritt 12, Bild 3 von 3
    • Remove the hard drive door with a spudger.
    • Lift the metal enclosure out of the plastic bottom case.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
iDeleted
2.101 Reputation
39 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 1,913
