Einleitung
This guide is to be used to install the SD card in the case that the SD card is damaged or no longer functions properly due to overuse. A Phillips screwdriver will be needed to complete this installation.
Was du brauchst
Using the thumb, firmly push the Battery/SD cover in the middle and in the direction of the arrow on the Battery/SD cover.
This will cause the Battery/SD cover to pop open.
Press down on the SD card. This will cause it to eject, thus enabling it to be removed.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
