Zum Hauptinhalt wechseln
Sanyo Katana Screen Replacement
Was du brauchst
  1. Sanyo Katana Screen Replacement, Screen Protector: Schritt 1, Bild 1 von 2 Sanyo Katana Screen Replacement, Screen Protector: Schritt 1, Bild 2 von 2
    • With the flat end of a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath.
  2. Sanyo Katana Screen Replacement: Schritt 2, Bild 1 von 2 Sanyo Katana Screen Replacement: Schritt 2, Bild 2 von 2
    • Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver.
  3. Sanyo Katana Screen Replacement: Schritt 3, Bild 1 von 2 Sanyo Katana Screen Replacement: Schritt 3, Bild 2 von 2
    • Carefully pry the screen protector off the phone using the flat end of the spudger.
    • This will require a bit of force as the back of the screen protector is lined with an adhesive material.
    • Once free from the adhesive, pull the screen protector away from the phone.
  4. Sanyo Katana Screen Replacement, Front Case: Schritt 4, Bild 1 von 3 Sanyo Katana Screen Replacement, Front Case: Schritt 4, Bild 2 von 3 Sanyo Katana Screen Replacement, Front Case: Schritt 4, Bild 3 von 3
    • Use the spudger to pry off the front case from the left and right sides of the device.
    • Once it has popped off, pull the casing apart with fingers.
  5. Sanyo Katana Screen Replacement, Screen: Schritt 5, Bild 1 von 2 Sanyo Katana Screen Replacement, Screen: Schritt 5, Bild 2 von 2
    • Using a Tri-wing Y0 screwdriver, remove the 4.4mm screw.
    • Use fingers to remove the strip from the device.
  6. Sanyo Katana Screen Replacement: Schritt 6, Bild 1 von 3 Sanyo Katana Screen Replacement: Schritt 6, Bild 2 von 3 Sanyo Katana Screen Replacement: Schritt 6, Bild 3 von 3
    • Use a spudger to detach all of the connections to the motherboard in the back of the phone by the screen.
  7. Sanyo Katana Screen Replacement: Schritt 7, Bild 1 von 2 Sanyo Katana Screen Replacement: Schritt 7, Bild 2 von 2
    • Use the flat edge of the spudger to detach the screen from the phone casing.
    • Pull the screen up and away from the case.
Abschluss
Aliceann
49 Reputation
1 Anleitung geschrieben
Clemson, Team 12-1, Benson Spring 2013 Mitglied von Clemson, Team 12-1, Benson Spring 2013
CLEM-BENSON-S13S12G1
4 Mitglieder
20 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 14
Insgesamt: 626
