Zum Hauptinhalt wechseln
Sanyo Katana Front Case Replacement
Was du brauchst
  1. Sanyo Katana Front Case Replacement, Screen Protector: Schritt 1, Bild 1 von 2 Sanyo Katana Front Case Replacement, Screen Protector: Schritt 1, Bild 2 von 2
    • With the flat end of a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath.
  2. Sanyo Katana Front Case Replacement: Schritt 2, Bild 1 von 2 Sanyo Katana Front Case Replacement: Schritt 2, Bild 2 von 2
    • Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver.
  3. Sanyo Katana Front Case Replacement: Schritt 3, Bild 1 von 2 Sanyo Katana Front Case Replacement: Schritt 3, Bild 2 von 2
    • Carefully pry the screen protector off the phone using the flat end of the spudger.
    • This will require a bit of force as the back of the screen protector is lined with an adhesive material.
    • Once free from the adhesive, pull the screen protector away from the phone.
  4. Sanyo Katana Front Case Replacement, Front Case: Schritt 4, Bild 1 von 3 Sanyo Katana Front Case Replacement, Front Case: Schritt 4, Bild 2 von 3 Sanyo Katana Front Case Replacement, Front Case: Schritt 4, Bild 3 von 3
    • Use the spudger to pry off the front case from the left and right sides of the device.
    • Once it has popped off, pull the casing apart with fingers.
Abschluss
StephenYH
20 Reputation
3 Anleitungen geschrieben
Clemson, Team 12-1, Benson Spring 2013 Mitglied von Clemson, Team 12-1, Benson Spring 2013
CLEM-BENSON-S13S12G1
4 Mitglieder
20 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 12
Insgesamt: 258
