Zum Hauptinhalt wechseln
PlayStation 2 Slimline SCPH-7500x IR Sensor Replacement
Was du brauchst
  1. Achtung: Die Schritte 1-7 stammen von einer Anleitung, die derzeit bearbeitet wird.
    • Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
  2. PlayStation 2 Slimline SCPH-7500x IR Sensor Replacement: Schritt 2, Bild 1 von 1
    • Locate the six feet on the bottom of the PS2.
    • Five of these feet are in plain sight while the last foot is located under the black void sticker on the back of the device.
    • Some versions of the console, such as the PAL Version, may not have this sticker. In this case, the foot or the screw should be in plain sight.
  3. PlayStation 2 Slimline SCPH-7500x IR Sensor Replacement: Schritt 3, Bild 1 von 3 PlayStation 2 Slimline SCPH-7500x IR Sensor Replacement: Schritt 3, Bild 2 von 3 PlayStation 2 Slimline SCPH-7500x IR Sensor Replacement: Schritt 3, Bild 3 von 3
    • Remove the five visible feet from the bottom of the device using a spudger.
  4. PlayStation 2 Slimline SCPH-7500x IR Sensor Replacement: Schritt 4, Bild 1 von 2 PlayStation 2 Slimline SCPH-7500x IR Sensor Replacement: Schritt 4, Bild 2 von 2
    • Remove the sticker and then remove the 6th foot.
  5. PlayStation 2 Slimline SCPH-7500x IR Sensor Replacement: Schritt 5, Bild 1 von 3 PlayStation 2 Slimline SCPH-7500x IR Sensor Replacement: Schritt 5, Bild 2 von 3 PlayStation 2 Slimline SCPH-7500x IR Sensor Replacement: Schritt 5, Bild 3 von 3
    • After all of the feet have been removed, Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2.
  6. PlayStation 2 Slimline SCPH-7500x IR Sensor Replacement: Schritt 6, Bild 1 von 3 PlayStation 2 Slimline SCPH-7500x IR Sensor Replacement: Schritt 6, Bild 2 von 3 PlayStation 2 Slimline SCPH-7500x IR Sensor Replacement: Schritt 6, Bild 3 von 3
    • Once all of the screws have been removed, pry apart the plastic covers. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate the two sides.
    • You may need to apply some gentle force to detach the covers. Be careful not to break the plastic screw pins.
  7. PlayStation 2 Slimline SCPH-7500x IR Sensor Replacement: Schritt 7, Bild 1 von 1
    • If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
  8. PlayStation 2 Slimline SCPH-7500x IR Sensor Replacement, IR Sensor: Schritt 8, Bild 1 von 3 PlayStation 2 Slimline SCPH-7500x IR Sensor Replacement, IR Sensor: Schritt 8, Bild 2 von 3 PlayStation 2 Slimline SCPH-7500x IR Sensor Replacement, IR Sensor: Schritt 8, Bild 3 von 3
    • Locate the IR sensor on the motherboard. Then, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Jared Hirata
880 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 17-4, Regan Spring 2013 Mitglied von Cal Poly, Team 17-4, Regan Spring 2013
CPSU-REGAN-S13S17G4
3 Mitglieder
28 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 1,875
