Einleitung
This guide will walk you through step-by-step on how to properly remove and install the IR sensor in the PlayStation 2 Slimline.
Was du brauchst
Schritt 1 Removing Playstation 2 Slimline SCPH-7500x Outer Shell
Achtung: Die Schritte 1-7 stammen von einer Anleitung, die derzeit bearbeitet wird.
Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
After all of the feet have been removed, Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2.
Once all of the screws have been removed, pry apart the plastic covers. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate the two sides.
If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
