Zum Hauptinhalt wechseln
BlackBerry 7290 Side Button Replacement
Was du brauchst
  1. BlackBerry 7290 Side Button Replacement, Battery: Schritt 1, Bild 1 von 3 BlackBerry 7290 Side Button Replacement, Battery: Schritt 1, Bild 2 von 3 BlackBerry 7290 Side Button Replacement, Battery: Schritt 1, Bild 3 von 3
    • Apply pressure to the lock button on the back of the device.
    • Slide the battery cover down towards the bottom of the device, revealing the battery compartment.
  2. BlackBerry 7290 Side Button Replacement: Schritt 2, Bild 1 von 3 BlackBerry 7290 Side Button Replacement: Schritt 2, Bild 2 von 3 BlackBerry 7290 Side Button Replacement: Schritt 2, Bild 3 von 3
    • Locate groove along the right side of the battery compartment.
    • Remove battery by prying between the battery and the groove.
  3. BlackBerry 7290 Side Button Replacement, SIM Card: Schritt 3, Bild 1 von 1
    • Slide the SIM card holder to the left to unlock the SIM card.
  4. BlackBerry 7290 Side Button Replacement: Schritt 4, Bild 1 von 2 BlackBerry 7290 Side Button Replacement: Schritt 4, Bild 2 von 2
    • Lift the SIM card holder up.
    • Gently remove the SIM card from the SIM card holder by sliding the card along the railing.
  5. BlackBerry 7290 Side Button Replacement, Side Button: Schritt 5, Bild 1 von 1
    • Locate the four screws along the perimeter of the back casing.
    • Remove the four top screws using a T-6 torx screwdriver.
    • The top four screws are .413 inches.
  6. BlackBerry 7290 Side Button Replacement: Schritt 6, Bild 1 von 2 BlackBerry 7290 Side Button Replacement: Schritt 6, Bild 2 von 2
    • Locate two screws within the lower edge of the inner compartment.
    • Remove the two bottom screws using a T-6 torx screwdriver.
    • The bottom two screws are .2 inches in length.
    • The second picture displays the device after the six screws have been removed.
  7. BlackBerry 7290 Side Button Replacement: Schritt 7, Bild 1 von 1
    • Use the plastic opening tool to apply pressure on the two clips that are located at the bottom of the phone.
  8. BlackBerry 7290 Side Button Replacement: Schritt 8, Bild 1 von 3 BlackBerry 7290 Side Button Replacement: Schritt 8, Bild 2 von 3 BlackBerry 7290 Side Button Replacement: Schritt 8, Bild 3 von 3
    • Remove the back casing from the phone by lifting the unhooked portion, then slide the casing towards the top of the device.
    • Make sure all clips holding the case together are unhooked, so no damage is caused to the case.
  9. BlackBerry 7290 Side Button Replacement: Schritt 9, Bild 1 von 2 BlackBerry 7290 Side Button Replacement: Schritt 9, Bild 2 von 2
    • Locate on the backside of the phone, a screw towards the top of the device.
    • Using a T-6 screwdriver, remove the screw.
    • After the screw has been removed, carefully lift the side button brace to reveal the side button.
Abschluss
Jschutt
79 Reputation
1 Anleitung geschrieben
Cal Poly, Team 19-6, Maness Fall 2009 Mitglied von Cal Poly, Team 19-6, Maness Fall 2009
CPSU-MANESS-F09S19G6
5 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 18
Insgesamt: 3,735
