Zum Hauptinhalt wechseln
Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard
Was du brauchst
  1. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Case: Schritt 1, Bild 1 von 3 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Case: Schritt 1, Bild 2 von 3 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Case: Schritt 1, Bild 3 von 3
    • Use a large plastic opening tool along the rear panel:
    • There are 4 clips to release.
  2. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: Schritt 2, Bild 1 von 2 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: Schritt 2, Bild 2 von 2
    • Slide the cover along the plastic frame.
  3. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, LED Light conducting plastic pieces: Schritt 3, Bild 1 von 1
    • Slide off the largest plastic pieces.
  4. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: Schritt 4, Bild 1 von 3 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: Schritt 4, Bild 2 von 3 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: Schritt 4, Bild 3 von 3
    • Bend the second small plastic piece to release it from the rubber piece.
    • Now you can slide it out.
  5. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Disassembling Western Digital Essentials HD Hard Drive: Schritt 5, Bild 1 von 2 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Disassembling Western Digital Essentials HD Hard Drive: Schritt 5, Bild 2 von 2
    • Slide out the hard drive as shown in the picture
    • Make sure to slide as shown or you may damage the USB bridge logic board.
  6. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: Schritt 6, Bild 1 von 2 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: Schritt 6, Bild 2 von 2
    • Remove the 4 rubber piece from the plastic frame at each corner.
  7. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: Schritt 7, Bild 1 von 1
    • Remove the rubber piece from the SATA/USB bridge logic board.
  8. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, SATA/USB Bridge Motherboard: Schritt 8, Bild 1 von 2 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, SATA/USB Bridge Motherboard: Schritt 8, Bild 2 von 2
    • Remove both screws holding the retaining plate and the hard drive.
    • Slide the retaining plate in order to disconnect the SATA connector.
  9. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: Schritt 9, Bild 1 von 1
    • Remove both screws holding the retaining plate with the logic board.
Abschluss
Gaetan
9.574 Reputation
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 1,995
