Was du brauchst
Use a large plastic opening tool along the rear panel:
There are 4 clips to release.
Bend the second small plastic piece to release it from the rubber piece.
Now you can slide it out.
Slide out the hard drive as shown in the picture
Remove the 4 rubber piece from the plastic frame at each corner.
Remove both screws holding the retaining plate and the hard drive.
Slide the retaining plate in order to disconnect the SATA connector.
