Zum Hauptinhalt wechseln
Toshiba Satellite A210 Keyboard Replacement
Was du brauchst
  1. Toshiba Satellite A210 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Satellite A210 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Unplug the AC adapter and all other auxiliary components from the laptop.
    • Slide the battery lock tab away from the center of the laptop to unlock the battery.
  2. Toshiba Satellite A210 Keyboard Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite A210 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Slide the battery release tab away from the center of the laptop and hold it.
    • Lifting from the small notch between the two tabs, pull the battery out of the laptop.
  3. Toshiba Satellite A210 Keyboard Replacement, Keyboard: Schritt 3, Bild 1 von 1
    • Unscrew the 4 highlighted screws with a PH1 screwdriver.
  4. Toshiba Satellite A210 Keyboard Replacement: Schritt 4, Bild 1 von 3 Toshiba Satellite A210 Keyboard Replacement: Schritt 4, Bild 2 von 3 Toshiba Satellite A210 Keyboard Replacement: Schritt 4, Bild 3 von 3
    • Orient the laptop so that the screen is open and facing you.
    • Slide the plastic opening tool underneath the top edge of the black plastic insert.
    • Pull it off and set aside.
  5. Toshiba Satellite A210 Keyboard Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite A210 Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Remove the 2 PH1 screws.
    • Lift the keyboard from the top being carful not to remove it fully. There is still a ribbon cable that connects the keyboard to the laptop.
  6. Toshiba Satellite A210 Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Disconnect the keyboard ribbon cable and remove the keyboard from the laptop.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Youlen
40 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 17-5, Regan Spring 2013 Mitglied von Cal Poly, Team 17-5, Regan Spring 2013
CPSU-REGAN-S13S17G5
4 Mitglieder
18 Anleitungen geschrieben
Ein Kommentar
very useful. THANKS
ANDREAS - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 21
Insgesamt: 2,603
