Zum Hauptinhalt wechseln
Toshiba Portege M400 Touchpad Replacement
Was du brauchst
  1. Toshiba Portege M400 Touchpad Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Remove the front face plate with a plastic opening tool.
    • Unscrew and remove the two 3.8mm screws labeled B3 with the #1 Phillips screwdriver.
  2. Toshiba Portege M400 Touchpad Replacement: Schritt 2, Bild 1 von 1
    • Lift the keyboard toward you starting from the edge closest to the screen.
    • This ribbon still connects the taptor to the keyboard.
    • Gently place the keyboard on top of the track pad with the keys upside down.
  3. Toshiba Portege M400 Touchpad Replacement: Schritt 3, Bild 1 von 3 Toshiba Portege M400 Touchpad Replacement: Schritt 3, Bild 2 von 3 Toshiba Portege M400 Touchpad Replacement: Schritt 3, Bild 3 von 3
    • Find the white ribbon connector (where the keyboard is still attached to the rest of the laptop).
    • Remove the screw on the metal plate that keeps the ribbon from sliding out.
    • Gently remove the metal plate and set it aside.
  4. Toshiba Portege M400 Touchpad Replacement: Schritt 4, Bild 1 von 2 Toshiba Portege M400 Touchpad Replacement: Schritt 4, Bild 2 von 2
    • Dislodge the white ribbon connector from the two clips holding it in place using the plastic opening tools.
    • Pull out the white ribbon connector with your fingers.
  5. Toshiba Portege M400 Touchpad Replacement, Touchpad: Schritt 5, Bild 1 von 2 Toshiba Portege M400 Touchpad Replacement, Touchpad: Schritt 5, Bild 2 von 2
    • Use a plastic opening tool to carefully remove the cover of the touchpad.
    • Remove the one 1/2" inch screw on the backside of the laptop.
  6. Toshiba Portege M400 Touchpad Replacement: Schritt 6, Bild 1 von 2 Toshiba Portege M400 Touchpad Replacement: Schritt 6, Bild 2 von 2
    • Gently pull up the touch-pad piece and lay it upside down.
    • The touch-pad will still be connected to the computer.
  7. Toshiba Portege M400 Touchpad Replacement: Schritt 7, Bild 1 von 2 Toshiba Portege M400 Touchpad Replacement: Schritt 7, Bild 2 von 2
    • Pull back the tab to disconnect the touchpad to the laptop.
Abschluss
Cal Poly, Team 4-17, Maness Spring 2013 Mitglied von Cal Poly, Team 4-17, Maness Spring 2013
CPSU-MANESS-S13S4G17
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 1,133
